Can we all post up pics of what exactly we use, more tools the bette i say |
I have always preferred to use a pneumatic 6" DA sander that locks the pad in a grinder like mode. switch the lock and re-sand with the same grit, that will remove the ledge created from switching directions (end of stroke) in the grinder mode.
When sanding with the pad locked you should see long curved lines and the pad should be almost flat to flat surfaces. The long sweeping lines make it easy to see the imperfections in the metal. When you unlock the pad you see lines that look the same as from a palm sander, these little overlapping circles hide imperfections like pits and other sanding lines. I call the grinder mode DQ (Do it Quick) and DA stands for dual action. I always use a belt grease to prevent galling of the metal, a little on the pad, and or, a little on the part. the heavier the grit the more the grease. I usually use 120 DQ then DA, 220 DQ / DA, and 320 just DA, then buff. WARNING{ deep ruts / heavy waves can be created quickly when grinding. Since you can't put the pad completely flat, you should move in the direction of the lean / tilt. Use a practice piece. |
But I do think I now know why I couldn't find a factory-made foam-roller belt sander...it's a b*tch getting a belt to track right with "flubbery drums". Sounds like a horrible disease, don't it...? |
Pics of the pits.
Should I continue working on them, or is it a lost cause. I'm thinking about Powder Coating them White, to match my Oxford White Mach 1. Last edited by ptim; 02-19-2007 at 07:49 PM. |
I could not make it much brighter. You have come very close to the limit of that material. I have seen and polished that type of Swiss,,, I mean casting and it is hard to maintain too. On the flip side only “other” polishers will pick that shine apart once you have installed it. If you keep it clean and cream polish it often, it will still look great under the hood. |
There may be some kind of hi-temp filler you could use before powdercoating, but if the outgassing continued it prolly wouldn't work. It's my understanding that these could be filled with a (few?) layers of copper, ground smooth, then plated, if that's the route you wanted to go. |
| Serious Help Needed, Polishing aluminum valve cover. | m3the01 | Metal Polishing Questions | 29 | 01-28-2008 12:57 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Very Newbie Question: Repairing scratches on aluminum anodized 50 years ago | filmfatales | Anodizing Questions | 2 | 01-26-2007 04:59 PM |
| aluminum oxide media question | corybarta | Powder Coating Questions | 5 | 10-19-2005 12:18 AM |
| Brand Newbie Aluminum Polishing Question | gdsegel | Metal Polishing Questions | 1 | 04-25-2003 09:04 AM |
