+ Reply to Thread
Page 1 of 5
1 2 3 ... LastLast
Results 1 to 10 of 45
Thread: Aluminum Valve Cover Question
  1. #1
    Default Aluminum Valve Cover Question
    I'm trying to polish a set of Valve Covers, I have a couple of questions.
    I'm seeing tiny pits in the aluminum, will they polish out or should I quit wasting my time.
    Its getting pretty smooth and shiney, I can see myself, but its not a mirror like finish, also, will the aluminum get a chrome finish.
    At this point which compound should I continue to use, I have black, brown, green and white.
    Also, how much compound should I use on the pads.
    I'm using a drill if it helps. Any help would be greatly appreciated.
    Thanks
    Share with Facebook
  2. #2
    Join Date
    Aug 2004
    Posts
    957
    Default Re: Aluminum Valve Cover Question
    Quote Originally Posted by ptim
    Pay close attention to the "pits".. If you see more "pits" the more you sand, it's bubbles in the metal. Stop sanding.
    It will get close to chrome, done properly. Usually it's enough to take it to 400 or 600 grit, then emery compound, then maybe tripoli and finish with white rouge.
    See above. Also read the polishing manual on this site.
    A quick jab or two at the spinning wheel is all you need every few minutes.
    I'm using a drill if it helps. Thanks
    Kind of slow but it can be done. A motor with 8" wheel would be better.
    Good luck.
    Share with Facebook
  3. #3
    I have a bench grinder, if I bought some adapters and pads, would it work better than my drill.
    Share with Facebook
  4. #4
    Join Date
    Dec 2006
    Location
    Dereham, norfolk, UK
    Posts
    97
    Id tend to stay away from a bench grinder converted mate. Its what iu started out with, waste of money if you ask me as a bench grinder dont have the power, when you stick your workpiece up to your mops/wheels the wheel will just stop and wnt do anything. I bought a heavy duty motor of a fella on ebay and there's no way i can stop it with pressure. Bench grinder now made redundanty in the back of the shed, same with a drill, no good because you cant get the speed out of them.
    Share with Facebook
  5. #5
    Quote Originally Posted by Tng21
    Thanks for the info, If the bench grinder isnt strong enough, what about an angle grinder.
    Share with Facebook
  6. #6
    Angle grinders work great. I like the older Makita 9217-spc
    The newer model 9227 is good too, they have a soft start so the grinder won't jump or jerk when you hit the switch with big wheels on it.
    They also are variable speed, have loads of torque, and will take more abuse than any other grinder.
    (My oldest of 3 is 7 years and counting / polishing)
    Another great thing about grinders is that they can be clamped to the edge of a table and used as a stationary machine.
    I use them for small or odd shape parts that are too dangerous to do on
    the 5HP, or big parts that can't be held to a buffer.
    I use them for sanding too, using an 6 or 8 inch sticky pad.
    The car and the bike were polished with Makita's
    The bike is mine, the car was done for Nitto tires and on display at the
    SEMA show in 05
    ...................................NOT CHROME...............................
    Share with Facebook
  7. #7
    Quote Originally Posted by UncleJimmi
    SEMA show in 05
    WOW, the car is awesome and I thought valve covers were hard to do.
    Share with Facebook
  8. #8
    Join Date
    Jul 2005
    Posts
    495
    ptim,
    I have used a 3/8" drill for polishing pieces that you can't get under a pedestal mounted buffer. A bench grinder probably won't be strong enough unless your bench grinder is using 8" grinding wheels. I use 4" or smaller wheels on my drill and have had good success. By the time you buy a pedestal, shaft extensions and wheels for your bench grinder you are almost to the place where it's less expensive to buy an 8" or 10" buffer!
    John
    Share with Facebook
  9. #9
    Join Date
    Aug 2006
    Posts
    78
    what is that car made out of? that thing looks absolutely amazing!
    you can do a good job of polishing with a bench grinder, but it can be frustrating since they don't have any power. i'd rather use a bench grinder than a drill, but an angle grinder rocks. i've got a 3.5hp motor and a bench mandrel to upgrade from my bench grinder as soon as i build a table for them.
    Share with Facebook
  10. #10
    Join Date
    Aug 2004
    Posts
    957
    Personally I'm not sure how these angle grinders are being used. Surely they exceed the rpm limits for normal cotton wheels, and 20,000 - 30,000 rpm is, um, overkill for simply polishing. But, as the name implies, they are the best for grinding...which is what they're made for.
    If these valve covers are all you're doing, you can do it with the drill - it'll just take a while. After all, Caswell sells a kit just for using a drill, so they must think it works...
    If you're going to do very many more parts, _then_ it might be worth it to get better equipment.
    Share with Facebook
+ Reply to Thread
Page 1 of 5
1 2 3 ... LastLast
Thread Information
Users Browsing this Thread
  1. Serious Help Needed, Polishing aluminum valve cover.
    By m3the01 in forum Metal Polishing Questions
    Last Post: 01-28-2008, 11:57 AM
  2. Something for you die hard polishers out there to chew on
    By thesound in forum Metal Polishing Questions
    Last Post: 12-03-2007, 12:16 PM
  3. Replies: 2
    Last Post: 01-26-2007, 03:59 PM
  4. aluminum oxide media question
    By corybarta in forum Powder Coating Questions
    Last Post: 10-18-2005, 11:18 PM
  5. Brand Newbie Aluminum Polishing Question
    By gdsegel in forum Metal Polishing Questions
    Last Post: 04-25-2003, 08:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
