I have already finished sanding all the way up to 1500, I then buffed with brown then white it came out great except the small scrathes, so i decided to go for some help, after going through this forum i decided to try the emery with a 4" sisal wheel to try and get better results. I finshed all of the compounds and then took a look, for some reason it is dull it never happend when i used only brown/white but now its just not as polished looking as before. any help on this would help a ton thx's
Sounds like you just aren't spending enough time with each compound. Use each compound until it won't get any shinier and then move on. If you overlap your runs at 45degree angles it will move faster.
Ditto! Stay away from 4" wheels unless you need to get in a tight spot where a 6" just won't fit, and what RPM are you running at? with a 6" wheel on a 3500 rpm grinder using emery compound you should start seeing a decent shine already.
I have a drill which says (0-2500 min-rpm) will this be enough power for the 6" wheels. also to marsfroggie's post 45 degree's from what? the last compond or the last pass with the buff? I also hade another post wher i was told to go with the sanding marks (when buffing) to eliminate most scratches and for best finish.
I was digging through my tools a found my die-grinder from campbell hausfeld, on the case of the grinder says 25,000 RPM MAX @ 90 psi. That number seems a little big so what im asking is if the number is true will this be better to buff with?
Make your first pass with say emery, then come back over it at a 45degree angle with the same compound. This cuts the metal down faster. You Just keep alternating the cuts until you get it how you like it. Do the same for each compound. Caswell's metal polishing guide has a more detailed description of the cut and color motions.
You can view the guide here: http://www.caswellplating.com/buffs/...61c359fc2ec72b |
The next thing i was wondering, whats the best hand polish to use when done with the compounds? i heard mothers wasnt that good, any suggestions? |
You can put some duct tape or something to cusion the impact on the arbor shaft to keep it from damaging your work too badly when you mess up. I like to use Mother's polish. I have also heard that eagle one polish is good. Make sure you go over it with a pure carnauba wax after you polish it to protect the shine. Caswell claims good results with Flitz, but I haven't tried.
| problems polishing aluminium alloy with white compound | rotorman | Metal Polishing Questions | 6 | 08-02-2004 01:57 PM |
| Cant get compound onto the wheels | 1105 | Metal Polishing Questions | 3 | 04-28-2004 10:05 AM |
| pushing compound about on aluminium | whistule | Metal Polishing Questions | 13 | 12-26-2003 12:32 PM |
| Consistency Problems | NeoMoses | Anodizing Questions | 6 | 12-13-2003 04:01 PM |
| White Compound Turns Black? | GrillMan | Other Metal Finishing Questions | 2 | 08-23-2003 03:12 AM |
