Old 02-20-2007, 07:16 AM
alininger2001 is on a distinguished road
Default How long does it take greasless to dry?
I just ordered some greaseless compound. I'm just curious, how long does it take to dry. I heard a blow dryer helps. How long am I looking at to reload?
Old 02-20-2007, 07:30 AM
Default Re: How long does it take greasless to dry?
Up to 10 minutes if it's humid and you do multiple layers. The hair dryer helps a lot, but watch you don't dry the outside and start using it with the inside still gummy.
Some people load up several tools at once and have them ready...it should save a little time.
Old 02-20-2007, 08:36 PM
Thanks for the help, about how long does it last before you have to reload. Can you use different compounds on the same bob?
Old 02-20-2007, 09:07 PM
alabama_lowlife will become famous soon enough
i've never really paid attention to how long it lasts, but as long as you stay away from edges it goes for several minutes it seems. you should not use more than one compound on a wheel....and with greaseless, more than one wheel per compound is a good idea because one wheel will dry while you're using the other one.
Old 02-20-2007, 09:41 PM
Tng21 is on a distinguished road
Send a message via MSN to Tng21
yep as they guys say, using a hairdryer certainly helps me, i find its best to use it on heat for about 30 seconds mayeb more, then flick the switch to cool and it goes hard withing a few more seconds, then load it up again. On felt bobs using a dremel type tool, ive found that it dont last too long really but for the short time its sanding, its takes out a LOT of time rather quickly. Ive bought about 8 bobs of each size and its a good idea keep them all seperate within grits.
Gotta have use one grit on one bob, if you went to a finer grit say 300 after using 240 on the same one, you'll be defeating the object of sanding smoother because the rougher 240 grit will still come through and you're back to square one.
On small tiny bobs and slightly larger ones, ive found its gonna cut out on so much time for me i couldnt do without it. Look through a few of my threads with other info that may help.
Gareth
Old 02-20-2007, 09:50 PM
So dou you have to load it up more that once before using it? If so how many times?
Old 02-21-2007, 07:30 AM
On small bobs or wheels I usually use three coats; on 8" wheels, two. The more coats, tha longer you can go between loadings. You need to make sure a layer is completely dry before applying the next.
Also, with felt bobs I usually use a hacksaw blade or sharp knife to make lengthwise cuts around the bob (not too deep) - it gives the greaseless a way to stick better.
Additionally, when I use felt bobs with regular compound, I clean them with a hacksaw blade or 80-grit paper.
  #8 (permalink)
Old 02-21-2007, 07:53 PM
like mpierich says, give it a few coats, on the felt bobs i load it up loads of times, takes a while but then it stops you loading up more frequently. Havent cut into my felt bobs like mpierich suggests so might give that a go but mine seems to hold pretty well anyway. mpierich by lengthways, do you mean from the tips on the bob to the widest part hearer the dremel tool, or around the circumfrence of the bob?
  #9 (permalink)
Old 02-22-2007, 06:30 AM
From the tip toward your hand, along the axis of rotation.
  #10 (permalink)
Old 02-25-2007, 07:50 PM
What type of wheel can you use greaseless with? Would it work well with a spiral sewn wheel?
Greasless compounds vs sandpaper 68commando Metal Polishing Questions 14 10-28-2006 02:31 AM
Greasless compound with used wheels? Tire_Shredder Metal Polishing Questions 2 01-24-2006 12:20 PM
how long does it keep inst2 Electroplating Questions 1 11-09-2003 05:40 AM
greasless compound spydersac Metal Polishing Questions 1 08-15-2003 01:13 PM
plating long pieces rjh1936 Electroplating Questions 1 02-20-2002 01:04 AM
