+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 19
Thread: Dumb question of the day: Read here
  1. #1
    Default Dumb question of the day: Read here
    Ok, here we go. I just received my drill buffing kit and am surprised at the value (very good). I have never buffed using the different bars of abrasive compound so here comes the question: The bar is hard/chaulky and how do I get it to the buffing wheels? Add water? I've seen pics of spreading the compounds but always thought they were soft. I've been buffing using paste type compounds so this is new to me.
    Share with Facebook
  2. #2
    Join Date
    Dec 2006
    Location
    Dereham, norfolk, UK
    Posts
    97
    Thumbs up Re: Dumb question of the day: Read here
    not sure i know what you mean as in hard chalky but normally on polishing compound the best way is to spin up the motor, then turn it off and hold the bar against the wheel till it stops, the flick the motor or dill on again and turn it off again and hold the bar against the wheel again and so on.
    That is if these bars you have are anything like the compound im talking about as my bars arent chalky.
    Anyone know if this fella has different stuff to what im on about?
    Share with Facebook
  3. #3
    Default Re: Dumb question of the day: Read here
    Tuch the bar compound to the spinning buff only for a second or 2
    the compound will only last on the wheel for one minute or so
    Just dab the bar, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff,
    Then switch compound and, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff, dab, buff,
    Welcome to the wonderful world of polishing
    Share with Facebook
  4. #4
    Join Date
    Dec 2006
    Location
    Posts
    97
    lol youll put him off like that jimmi lol
    but yeah, polishing can be a real pain
    Share with Facebook
  5. #5
    So this is all done "dry"? What I meant by chalky is that they are very dry and not soft like a putty. Maybe I was looking at he greaseless thinking they were what I purchased. And Jimmi...that makes me want to get in the fetal position and give up....but I want to do this badly.
    Share with Facebook
  6. #6
    The rewards of reflections by your own hands are priceless
    Just remember that polishing is really two projects 1st sanding, 2nd buffing
    generally, sanding is 75% of the job. Like a car in the paint booth, all the real work was done before it gets sprayed and if body work is wavy the paint will high lite the flaws.
    Your compound is fine, it has a melting point that is quickly reached from frictional heat. If you can handle the drill with one hand, you can dab the compound wile you are working. The compound will load up on the wheel and part this way and is only helpful in the cutting portion of the process (the first set of buff, dab's) The 2nd set is called coloring (the final buff)
    Share with Facebook
  7. #7
    Join Date
    Aug 2006
    Posts
    78
    yeah, you got the right stuff man. it seems odd at first, but once you see it work you start to understand it.
    Share with Facebook
  8. #8
    Thanks alot for that bit of info about the melting point..that makes it easier to understand. Thanks for your input guys.
    Share with Facebook
  9. #9
    Join Date
    Aug 2004
    Posts
    957
    If you have a good-sized vice you can wrap your bar in a rag and hold it in the vice - just let a 1/2" stick up. Or find another way to hold your compund securely. Putting compound on a drill-mounted wheel one-handed is a pain, and can be somewhat dangerous.
    Share with Facebook
  10. #10
    Quote Originally Posted by mpierich
    I was just getting a plan together to keep things together and safe. I am not going to base all of my jobs on the drill buffing method. I already have a good workbench and a few other supplies including a large grinder/buffer and this weekend I'm getting the stand for that. Almost have everything to start my "shop".
    Share with Facebook
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Thread Information
Users Browsing this Thread
  1. This will probably be a dumb question for all you experts
    By dwoodruff in forum Powder Coating Questions
    Last Post: 12-03-2007, 09:19 PM
  2. Ok, this one is straight out of the dumb question 101 book
    By olddude in forum Other Metal Finishing Questions
    Last Post: 08-24-2006, 12:14 PM
  3. Dumb question on curing.
    By remotestartdepot in forum Powder Coating Questions
    Last Post: 04-28-2004, 08:35 AM
  4. A really dumb question - hand vs machine polishing.
    By c_gismo in forum Metal Polishing Questions
    Last Post: 11-05-2003, 10:55 AM
  5. dumb anodizing question
    By felix in forum Electroplating Questions
    Last Post: 08-06-2002, 08:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
