Old 04-02-2007, 04:21 PM
soccergk is an unknown quantity at this point
Default can I use a die grinder with a buffing wheel? hazy reflection questions too
I dont have the funds to purchase a bench machine, i can get a die grinder and use the bit attatchment with a buffing whe and rouge. will this get the job done? I finished one wheel up to 3000 grit and the reflection is cloudy. will it buff out to a mirror finish?
Old 04-02-2007, 05:44 PM
Default Re: can I use a die grinder with a buffing wheel? hazy reflection questions too
Originally Posted by soccergk
I dont have the funds to purchase a bench machine, i can get a die grinder and use the bit attatchment with a buffing whe and rouge. will this get the job done? ?
Too fast, unless you get a variable speed model - and then it prolly wouldn't have the guts to turn a 4" wheel. Use a drill or flex shaft.
Yep, it sure should.
Old 04-02-2007, 05:52 PM
with the air one you can control the speed. i thought a drill wouldnt be fast enough?
Old 04-02-2007, 07:52 PM
Rasper will become famous soon enough
Yes. I use an air die grinder with a two inch wheel and it works fine for small pieces.
Richard
Old 04-03-2007, 07:29 AM
If you can slow it down and still have enough power, it will work. But normal fixed die grinder speeds run the risk of exploding a decent-sized wheel. The safety factor is up to the operator.
A drill is fast enough for what you want to do.
Change buffing wheel for different metals? MThings Metal Polishing Questions 7 12-14-2006 07:25 PM
Alloy wheel polishing questions db_abz Metal Polishing Questions 5 08-24-2006 03:31 AM
Electric die grinder mikekozura Metal Polishing Questions 9 03-05-2006 11:23 AM
What blasting media? mpierich Metal Polishing Questions 21 08-30-2005 09:30 AM
Final Scratches from buffing wheel regulator Metal Polishing Questions 2 01-06-2005 11:03 PM
