Buy One, Get One Free Buffing Wheels
Old 04-05-2007, 07:46 PM
soccergk is an unknown quantity at this point
Default black or white rouge with aluminum? or both and in which order? need help asap please
which do i use first the black or the white? do i use both with different buffing wheels?
working on this, up to 3k grit
Old 04-05-2007, 08:39 PM
Default Re: black or white rouge with aluminum? or both and in which order? need help asap please
ok just did some searching im going to go with the white because there arent really any scratches left
Old 04-05-2007, 08:41 PM
alabama_lowlife will become famous soon enough
use black first then white. always use a different wheel for each compound. and if you've got those sanded to 3000 grit, you'll only be stepping backwards with black, just use white and see how it turns out. if it's not good enough, then back up to black.
Old 04-06-2007, 05:59 PM
it kind of looks like the white is putting scratches in it, but the cloudyness is less, is there a fine rouge i should be using?
Old 04-06-2007, 07:05 PM
well, blue is finer than white. you could try it
Old 04-07-2007, 07:13 AM
polierator is on a distinguished road
Yes. Blue is the finest rouge so far as i know. I use it as the last rouge.
My steps are brown, green, white and at last blue.
Old 04-07-2007, 10:16 AM
so should i be using the cutting then the polishing motion? or just the polishing motion?
