John |
CASBEN,
I think your best bet would be to start with 'flap rolls' or a die grinder with cartridge rolls. Using a die grinder with cartridge rolls you have to be careful not to gouge the aluminum. You can get almost any grit and dimension of flap rolls to fit into the areas that you want to polish. After you get everything sanded to where you can start polishing I would wet sand with 400 grit wet and dry then start to polish. I would also have them media blasted with 100 - 120 grit prior to doing any sanding. You could also use Aircraft stripper to remove the coating. This will make your sanding a lot faster, as it will remove the coating that is already on the wheels and you won't have to sand it off. John |
Hand sanding with a piece of rubber or hard sponge as a back up pad would cut faster, but it is harder work. Time vs. sweat? Which do you have more of? I almost always hand sand aluminum, and I make it less boring by doing it in small increments of time, spaced with working on other things in my shop that I am doing. That way it gets done over time without too much pain. Also I get better results because I am not trying to just get it over with.
Richard |
John |
I succesfully sanded out the80 grit witha 100 grit on a rubber block. I took breaks every 30 minutes so it wouldnt feel so painful.Then i moved on to 150grit it made the surface real smooth so I tried the black/and spiral and brightened it up real nice (a littledull but you could still see your reflection)but i did find some scratches i couldnt buff out, i thinkit was from the 100grit. When i tried the black/spiral in some parts of the rim it left heavy black residu. is it because i use too much compound? or should i sand all the way to 400 and then try buffing?
I succesfully sanded out the80 grit witha 100 grit on a rubber block. I took breaks every 30 minutes so it wouldnt feel so painful.Then i moved on to 150grit it made the surface real smooth so I tried the black/and spiral and brightened it up real nice that you could see your face (a little hazy but thats just the first wheel)but i did find some scratches i couldnt buff out, i thinkit was from the 100grit. When i tried the black/spiral in some parts of the rim it left heavy black residu. is it because i use too much compound? or should i sand all the way to 400 and then try buffing?
sorry for the double posts my computer died on me |
you need to sand further than the 150 i usually stop at 400. if you still have scratches from the 100, you need to keep sanding with the 150 until you have all those scratches out.
on the heavy residue, could be excessive compound it doesn't take much. what are you using to polish? a drill? maybe the coarseness of the sanding is making it leave that residue? |
| felt bobs and greaseless not working for me | alabama_lowlife | Metal Polishing Questions | 2 | 01-18-2007 11:16 AM |
| Need help with first real job estimate | UnorthodoxCreations | Powder Coating Questions | 4 | 12-19-2006 02:52 AM |
| Greaseless or abrasive ahesive system????? | chaotik | Metal Polishing Questions | 7 | 10-30-2006 07:08 PM |
| How do you use greaseless? | gagnon | Metal Polishing Questions | 3 | 03-21-2003 05:43 PM |
| greaseless compounds | saiyan7 | Metal Polishing Questions | 4 | 04-12-2002 07:29 PM |
