to load it up with regular compounds (not greaseless) just hit it on the wheel for a couple seconds. occasionally you need to "rake" the wheel to remove built up compound and metal particles.
When greased compound builds up, it's either because there's not _enough_ compound on the wheel (yes, that's right), or you have not done the previous steps sufficiently.
Sorry for not replying sooner but my internet was disconnected and i had lost all hopes of seeing a mirror on my wheels. But last night i started sanding them again and got to 400grit and then started buffing a small section. I am kind of proud the way it came out for a first timer, but i still aint satisfied. The reflection isnt clear but bit hazy. From far away it looks nice, but if you look closely you can notice a criss-cross patern on the surface. I worked my way from the coursest compound to the finest but i cant fix it. Am i not taking enough time for each compound to move to the next? I am not sure what causes it but i think it might be the wheels i an using. I haven't cleaned then and old compound has dried on them.
I wanted to post some pictures for you all to see what im dealing with but the pictures exceed the amount of memory i am allowed. does anyone know how i could still post them so it would be of help(copy and paste didnt seem to work) Last edited by CASBEN; 05-31-2007 at 09:41 PM. |
CASBEN,
The cross-hatching you are seeing is from your sanding. You want to use a sewn wheel with Emory (black) compound until these scratches are buffed out. By all means you want to clean your buff of the used compound, this will hamper your buffing effort. Just lightly touch the compound to your wheel and replenish when necessary. After buffing you can use acetone or brake cleaner to clean the compound off your metal. John |
I dont think the criss-cross patern is from the sanding. I used a da sander to sand them and the scratches were circular. The buffing wheels are the ones i used at 90 degrees befor the previus. I want to post some pictures but need help on doing it.
I finally managed to make the pics smaller. This is how it looks after i sanded to 400g and worked my way from the black to the white compound. The surface is very smooth but not very shiny. I have tried diferent ways to do it but so far this is the best it has comed out
on my friend's wheels i kept getting a haze like that when i went to brown or white. i eventually used emory on a cushion buff and left it at that. it looks good enough for him to be happy with it so i am too.
| felt bobs and greaseless not working for me | alabama_lowlife | Metal Polishing Questions | 2 | 01-18-2007 11:16 AM |
| Need help with first real job estimate | UnorthodoxCreations | Powder Coating Questions | 4 | 12-19-2006 02:52 AM |
| Greaseless or abrasive ahesive system????? | chaotik | Metal Polishing Questions | 7 | 10-30-2006 07:08 PM |
| How do you use greaseless? | gagnon | Metal Polishing Questions | 3 | 03-21-2003 05:43 PM |
| greaseless compounds | saiyan7 | Metal Polishing Questions | 4 | 04-12-2002 07:29 PM |
