Old 05-15-2007, 03:34 PM
shaunb is on a distinguished road
Default Skinny buffing wheel for thin spaces?
Hi all,
With tech I've gained from this forum, I've made great progress with my polishing job so far. Now I've gotten stuck... I'm trying to polish the grooves on this brake caliper:
My 1/2" wide wheel is just too wide to get down in there and lean on it with some emery. Any suggestions on a skinny (1/4" wide max) solution?
I will end up doing this in low production #'s so want something that works well but doesn't take hours and hours...
Any ideas?
Old 05-15-2007, 06:52 PM
alabama_lowlife will become famous soon enough
Default Re: Skinny buffing wheel for thin spaces?
caswell sells a "razor buff" that is precisely what you need. they are about 1/8" thick and you can get them in 4,6,and 8" diameters. you could double stack to get it a little thicker if needed. they are not, however, stiff enough to really lean on very hard.
http://www.caswellplating.com/buffs/razor.html
Old 05-16-2007, 01:47 AM
tbreaden is on a distinguished road
Caswell sells a 3x1/4 spiral sewn wheel that will work on a die grinder or drill.
Change buffing wheel for different metals? MThings Metal Polishing Questions 7 12-14-2006 08:25 PM
Brand new buffing wheel shredding?!? chefboiali Metal Polishing Questions 10 07-16-2006 07:08 PM
What blasting media? mpierich Metal Polishing Questions 21 08-30-2005 10:30 AM
Final Scratches from buffing wheel regulator Metal Polishing Questions 2 01-07-2005 12:03 AM
2HP Caswell Buffing Wheel agugliel75 Metal Polishing Questions 1 05-09-2003 02:14 PM
