Old 05-18-2007, 12:50 PM
Moko is on a distinguished road
Default Help w/ newbie's SS project
Hey gang, this is a great forum and in general I've been able to learn a lot. I've got a new project refurbishing a couple of espresso machines. I'm starting from scratch when it comes to polishing and buffing the stainless steel on these machines so I'm coming to the experts for help.
I need to buy tools and wheels and well everything, so any help will be appreciated.
I've added some pictures. The first one is an example of a mirror finish before and after. Any tips on how to get this done?
And this picture shows a refurbished machine with the the mirror finish and the brushed finish. I'm at a loss about the brushed finish, do I have to polish and then rebrush? How do you rebrush?
I have lots more questions and pictures. I'll check back in a couple of days and see if anyone wants to play. Thanks
Old 05-19-2007, 12:55 AM
CarWiz's Avatar
Default Re: Help w/ newbie's SS project
The mirror SS comes from the factory polished but you should be able to restore the shine. Depending on how deep the scratches are, you may have to power sand them out. I use a DA (Dual Action) air sander on curcular to sand out scratches and defects. Start with 180 grit then down to 400. You could use 600 but as the 400 wears, it polishes. The problem with any mirror finish is that you'll need to blend your sanding so that it's even and feathered into the rest of the panel. If you don't, polishing will exacerbate any flaws.
The "brushed" look is acually done by sanding. I use a straight-line auto body sander with 80 grit. Run the length of the panel with the sander straight. You could also use a flat belt sander. A guide would help as you must keep the sanding going parallel. A moving start blends any overlap. You will have to practice.
I've repaired and renewed many SS trim pieces and radiator shells. Some you would think were ready for the scrap yard. Patients and practice wins out. Good luck and keep us posted on your progress.
Old 05-19-2007, 09:35 AM
alabama_lowlife will become famous soon enough
that sums it up quite well. i can't really think of anything to add.
Cooking up an oven project... dagobert Powder Coating Questions 33 06-09-2008 03:43 PM
my first project. grommit Powder Coating Questions 6 02-15-2007 09:35 AM
Preliminary project questions arynearson Electroplating Questions 1 11-28-2006 10:09 PM
First Polishing Project gmascolo51 Metal Polishing Questions 3 07-01-2005 03:28 AM
Marine project treat Electroplating Questions 1 10-15-2002 12:53 PM
