Old 05-24-2007, 04:04 PM
mach1canuck is on a distinguished road
Default Grinder choice + questions.
Hi, I've been lurking for a while, and now I have a question.
I have been using 4" buffs/greaseless/compounds w/ a hand drill for a while and although I get good results, it takes a long time.
I am looking to step up to a bench buffer, up in canada there isnt a whole lot of selection. So I am a little stuck converting a bench grinder.
Here is my choice:
Specs:
General International 8'' Bench Grinder.
Wheel Sizes: 8'' x 1'' (203 x 25.4 mm).
Arbor Speed: 3450 RPM.
Arbor Size: 5/8'' (16 mm).
Wheel Grits: 36/60.
Motor 1 HP, 110 V, 1 Ph, 8 A.
Weight: 59 Lbs. (27 kg).
The shafts dont stick out very far, and the housing is rather bulky, so I will be looking at something to extend them.
Now I know caswell sells shaft extenders that I can use on a motor with a flat on the shaft for the grub screws...,
But has anyone used them on a grinder shaft that has threads?
Do the grub screws mess up the threads?
Does the shaft extender grab enough "meat" to hold it on there when I'm getting on the buffs pretty hard?
Thank you for looking, I'll post up some pics of my work soon.
Cheers
Old 05-25-2007, 10:14 AM
jwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of lightjwilbert is a glorious beacon of light
Default Re: Grinder choice + questions.
The shaft extenders will hold great. As far as the threads go, I think that it will leave some flat spots. I can't guarantee that it wont' do anything to them.
A few questions from those that know. JTW37 Powder Coating Questions 4 04-05-2007 10:59 PM
Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions ms042180 Electroplating Questions 3 12-21-2006 11:48 AM
Electric die grinder mikekozura Metal Polishing Questions 9 03-05-2006 11:23 AM
Questions about buffers inline4 Metal Polishing Questions 2 02-06-2005 06:34 PM
whats up guys, few questions here red99ls1ta Powder Coating Questions 1 11-12-2003 06:58 PM
