Are you like me and need help doing the small details?
Small short radius inside corners getting you down? ****ed of at your dremel cause it doesn't seem to help you? Check out this post I found, buddy is a dremel wizard. How to polish small details. |
ANd I used cratex, and I found it only puts a shine on parts, and if there are bumps, it will only make shiny bumps. |
Do a Google on the rolls...we can't discuss others' products on here...they are available in 1/4" but not in finer grits. The homemade stuff is pretty much the only way to get finer grits in that form.
I have to agree on the Cratex but you can always use small felt bobs with greaseless compound for material removal. Quote:
mach1canuck, and mpierich,
I went to the 3M web site and found 1/4" rolls up to P240 grit and I also found 3/16" rolls up to P180 grit. Use the phone book, yellow pages and look under "abrasives". I have a local distributor that sells by the piece, but the standard package is 100. Good luck. John |
Yuh, I already get 1/4" rolls up to 320. But in my experience the forum-masters here don't appreciate the touting of other suppliers. It's their forum, so whatever...thanks anyhow.
Thanks for the suggestions guys! Found a spot to order 1/4", and 1/8"!!! rolls in 100, 180, 240, 320 grit.
Also, the same spot had the ceramic stones for very close in detail work. Jewellery supplies, and mold-finishing sites seem to have the same needs as we do. |
| How do you polish the tiny details ? | moto-chrome | Metal Polishing Questions | 6 | 04-28-2006 06:53 AM |
| More details on the sealing process, please | NeoMoses | Anodizing Questions | 2 | 11-10-2003 08:42 PM |
