Old 03-16-2003, 02:59 PM
ezmoney23
Default Greaseless or Sandpaper???
I'm new to polishing and I would like to know if the greaseless compounds will take the place of sanding(on a bike frame)
Old 03-16-2003, 06:20 PM
marsfrogie
Send a message via AIM to marsfrogie
Absolutely, they save hours upon hours of work compared to hand sanding.
Old 03-17-2003, 03:00 AM
hue hue is offline
hue
i have to agree with marsfrogie, but i will ad this, the greasless is great but the only downfall is ive only seen it go up to 320 grit. which you still need to hand sand from their, but it does save a lot of time
Old 03-17-2003, 03:31 AM
ezmoney23
Default Thanks
Thanks for the information!I have another question.Do I need to use aluminum oxide sandpaper all the way to 1500 or will regular body sanpaper work? The reason I ask is all I can find up here in alaska is 320 grit aluminum oxide paper. Thanks again and I will post a before and after pic of my bike.
Old 03-17-2003, 08:54 AM
marsfrogie
You should be able to go to emery after 320 grit. It should not be necessary to wetsand past 600 by hand.
Old 03-19-2003, 12:15 AM
hue hue is offline
hue
bummer that means i would have been done with sanding 3 weeks ago o well the extra steps to 1500 kept me busy for a while....wher were u before i started....DOH
and for your question i dont think the higher grits i.e 400-2000 are made with aluminum oxide i could be wrong, but caswell sell's all kinds of sandpaper below is the link!
http://www.caswellplating.com/buffs/wetanddry.htm
Old 03-19-2003, 08:57 AM
marsfrogie
It would only be necessary to sand to 2000 if you were taking the maintenance standard approach of using a hand polish. || The sandpaper could be Silicon Dioxide.
First time with greaseless! rides20 Metal Polishing Questions 1 08-19-2005 07:04 PM
Buffing wheel cement or greaseless turbohardtop Metal Polishing Questions 1 08-03-2005 11:24 AM
Is greaseless cheating? Plus a ? berad001 Metal Polishing Questions 7 06-14-2005 02:05 PM
How do you use greaseless? gagnon Metal Polishing Questions 3 03-21-2003 05:43 PM
greaseless compounds saiyan7 Metal Polishing Questions 4 04-12-2002 07:29 PM
