Old 07-03-2007, 08:44 PM
upncoming's Avatar
upncoming
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
Red face 8" shaft bench grinder/buffer ?
hey im just shopping around and im at the stage where im able to get a buffing machine. im looking around on ebay and came across one of these and i just wanted to know if anybody used one or know if its worth getting
http://cgi.ebay.com/ws/eBayISAPI.dll...4881&rd=1&rd=1
D.I.L.U.S.I.
Drive It Like You Stole It
Old 07-04-2007, 11:03 AM
Default Re: 8" shaft bench grinder/buffer ?
upncoming,
Either that one or one from HF. Caswells also has good buffing machines.
John
Old 07-18-2007, 12:56 PM
y2kgtp is on a distinguished road
"Please note: this item is not for professional industrial use, it is intended for hobbyists"
In the listing....makes me wonder how durable it is.
Personally I'm looking at a couple sears units, 1HP & 1.5HP models, for 99$ & 149$ respectively...prob will get the 1.5HP
http://www.sears.com/sr/javasr/produ...cemldffidfni.0
Old 07-18-2007, 01:57 PM
grommit's Avatar
grommit will become famous soon enough
hello there,
the advice i got and what i would say to you is buy what you can afford,i had the same buffer but lets face it this was really for beginning practice.some of the experienced guys say to go for the more expensive buffer,i agree coz you will only need another one if the cheap or under powered one goes wrong. when you are working on your metal you don't want your buffer to be struggling and producing poor results on your metal.
good luck
grommit
Old 07-18-2007, 10:36 PM
chromo
Just curious why more people don't use the jackshaft type with a seperate motor. Is there a reason? I am thinking of building this type myself.
You know what I mean I'm sure, the 2 wheels on a shaft with the bearing on each end and the pulley in the center. Add any motor you want, like a 2hp from a junk air compressor. I think an advantage would be variable speed with multie grove pullies also. Like my drill press has.
There's the little pillow blocks holding the bearings and that pulley, but no big motor housing to get in the way. If the motor ever burns up just swap in another used motor cheap, not replace the whole thing. I just did that on the lathe, fast easy swap when the motor burned up.
Most people find 1/2hp-3hp motors cheap everywhere if you look around. I have a bunch going up to 5hp just sitting here. Lots of 120Vac motors and 240Vac in smaller sizes.
It seems all my big power tools use a motor and belt drive, lathe, mill, Drill press, band saw, etc.. so any reason not to use a belt drive buffer?
Old 07-19-2007, 06:49 AM
The best stand-alone buffers have long shafts for access, and direct-drive means you aren't losing any power to the belt/pulley arrangement.
But, the power loss is not large and there's no reason not to use the other setup. My homemade belt sander uses a motor with a shaft at each end. Eventually I'm going to use the other end for an extra buffer - just need to make idler pulley arrangement for each side so I can run one or the other without running both at the same time.
You can buy a bench-mounted base with shaft and bearings already made up, just add motor.
Old 07-23-2007, 11:49 PM
chromo
I'll be making up the pulley and motor type then. I have lot's of motors of various types laying around.
  #8 (permalink)
Old 07-24-2007, 07:19 AM
If are able, and haven't thought of it already, you might want to make it "upside down" so it's suspended instead of on a pedestal or bench. Then you have unlimited space under the wheel where all the work gets done.
  #9 (permalink)
Old 07-29-2007, 11:06 AM
chromo
I had not thought of upside down, but that sounds like a good idea. I'll have to see what I can build that way.
  #10 (permalink)
Old 07-31-2007, 09:53 AM
I saw a fella made one from 4x4's - used a triangular piece of plywood (x2) for a stiff brace between upright and arm.
Build up bearing seat area on shaft? Daveleeander Other Metal Finishing Questions 1 03-13-2007 02:03 PM
help choosing a bench grinder/buffer grommit Metal Polishing Questions 13 04-06-2006 04:00 AM
Buffing speeds & flex shaft? Tallman Metal Polishing Questions 2 06-13-2004 12:19 PM
Shaft Extenders Rickc Metal Polishing Questions 5 04-10-2004 09:40 PM
