Jim |
You should purchase caswell's greaseless compounds kit. 180 grit greaseless would blast the chrome off. This takes hand sanding down to an absolute minimum. After the 240 you could go the the emery compounds and then to tripoli and white. If you want to take a chemical approach to removing the chrome you could use a battery charger and caswell's anodize and chrome remover. If I remember correctly you hook the chrome piece to the positive terminal, and place a swab covered anode on the negative end. You then place the swab in the solution (sodium hydroxide I believe) and then stroke the chrome plated piece. The chrome will then come off slowly.
You remembered correctly. It's the opposite connections to plating (reverse plating)
Are you sure its chrome plated? Most side trim from the 60s was anodized polished aluminum. You can strip the anodize with drain cleaner. Then polish.
You can also use our Chrome & Anodize stripper. It's much easier to use than drain cleaner. It gets the job done quickly in one application.
See http://www.caswellplating.com/kits/aluminum.htm
"hook the chrome piece to the positive terminal, and place a swab covered anode on the negative end. You then place the swab in the solution (sodium hydroxide I believe) and then stroke the chrome plated piece. The chrome will then come off slowly"
Is there anywhere I can find detailed instructions on this process? What is the swab made of? How quickly is it supposed to work? I have the caswell stripper but the lable was damaged so I cant see the instructions... Thanks |
| Removing small scratches from Chrome | mlust | Metal Polishing Questions | 5 | 07-30-2008 03:39 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Stripping chrome plating from aluminum | bbqboyee | Anodizing Questions | 4 | 04-22-2006 02:22 AM |
| removing copy chrome from aluminum | impactelectro | Electroplating Questions | 1 | 03-17-2004 01:49 PM |
| Removing blistered chrome from aluminum wheels? | ozziepartsguy2003 | Electroplating Questions | 0 | 12-14-2003 07:26 PM |
