I am having a rough time stripping some aluminum wheels. They are factory Dodge wheels and are painted and clear coated. I have tried gasket remover and even aircraft remover. They both work great for removing the paint and clear. HOWEVER, once they are removed, a white sealer (or primer?) is revealed. It feels like some type of latex material and it laughs at the stripper. I have used 60 grit sandpaper and have also tried sandblasting it. Both methods leave a lot to be desired. The sandblasting is VERY slow (sorry, I don't know the grit but I would guess it's medium), as the vast majority of it seems to bounce off the "latex" coating. The 60 grit sandpaper is obviously a chore plus all the extra sanding steps needed to get it where I can start polishing takes days. I don't mind hard work but I seem to be making this much harder than it should be. I know there is an easier way to get to the bare metal. I would greatly appreciate your input.
Not an expert on coatings, but in the case of powdercoating I do know that you can get it baked off, so that might work on other coatings. Beware of excessive heat affecting the strength of the metal though. I would first contact the manufacturer to see what material it is, then go from there.
Hmmm...just thinking here, but what if you were to lightly play a propane torch flame across it...maybe it'll char or bubble and come off. Watch those fumes, though... Last edited by mpierich; 10-15-2007 at 11:09 PM. |
Thanks for the reply. I don't think it's a powdercoating. It seems more like a rubbery latex coating. Kinda like dried latex enamel house paint. Once a bit of it flakes off and you pull on it, it stretches. As for the propane, I had actually thought of that. I was worried that I might discolor the aluminumm, though. What do you think?
Good point. I'm a newbie so I didn't know how hard discoloration was to remove. I think I'll still try it in a small hidden area first (as mpierich recommends). BTW, can i assume that most other painted wheels DON'T have this "sealer"? ie. are they simply painted with clear over that?
Anyone else wanna shed some light on whether or not all painted wheels have this primer from Hades?? I guess I could buy some salvage yard wheels and try them but it would be much easier to hear it from you guys first. Thanks again for your help.
Did you try burining it off with a torch yet?
| Stripping Chrome Wheels? | PacificSwell | Other Metal Finishing Questions | 2 | 04-10-2007 01:38 AM |
| Stripping aluminum | caver | Other Metal Finishing Questions | 2 | 01-27-2007 12:02 AM |
| aluminum wheel stripping? | renuwheels | Metal Polishing Questions | 5 | 05-03-2006 11:21 AM |
| Stripping chrome plating from aluminum | bbqboyee | Anodizing Questions | 4 | 04-22-2006 01:22 AM |
| stripping anodizing off aluminum | broker1234 | Metal Polishing Questions | 1 | 01-16-2005 09:28 PM |
