  #11 (permalink)
Old 10-25-2007, 06:06 AM
Default Re: T6-6061 Aluminum sanding questions
Originally Posted by baz View Post
i havn t done shovel head cases for a while but caveman castings is probably an understatement i that case . for the tight areas i make my own cartrige rolls
i have different size and shape mandrels with a split opening so i insert and roll my abrasive paper on it , might sound caveman type way of doing but i get the roll the size and shape i need in the grit that i want . have a look at my vrod engine in the member galery .i dont like working with real cartrige rolls
the tips wear out too fast i go through a box of 100 in no time
Yeah, I had forgot about the split mandrels...since I usually stop around 320-400 never really needed 'em. Now, if I ever have time to polish my _own_ stuff, heheh...
For the cart rolls, I got extra mandrels in the various lengths. Nip off half the smooth end part and you can use it for worn rolls - get twice the use out of them.
  #12 (permalink)
Old 10-25-2007, 08:36 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
yeah i do that too when i work with cartriges. i was woking on twin cam heads today , a full polish show job
even the 3/16 rolls are too wide to get inside most places
baz
http://www.polissagepb.com
chrome for small aluminum (6061 and 7075) parts - metro ny area offby1 Services Offered/Wanted 3 09-11-2007 12:46 PM
Sanding questions Tng21 Metal Polishing Questions 13 01-23-2007 07:13 AM
Virbratory finishing of 6061 aluminum. Need advice. tndiverdown Metal Polishing Questions 4 03-06-2006 11:15 PM
wet sanding questions cantex Metal Polishing Questions 3 02-13-2006 01:59 PM
polishing 6061 aluminum w/bad results clockman Metal Polishing Questions 6 05-16-2004 05:41 PM
