  #11 (permalink)
Old 11-26-2007, 09:20 AM
Default Re: What is the best way sand aluminum and to be able to do it fast?
Originally Posted by quadracer2cool4u View Post
I use the greaseless for sanding. Do you think stoping at 240 grit is enough?
Thanks!!!!!
For aluminum I stop at 320 or 400 (maybe 600 paper if it's a large flat surface), then go to emery/spiral etc.
I found sand blasting aluminum prior to powder coating is a big no-no. mtumbleson Powder Coating Questions 59 04-07-2008 07:37 PM
Sand for blastung aluminum wheels gtabadboy Powder Coating Questions 6 08-24-2005 09:04 AM
What sand can be used to sandblast powder off aluminum wheel gtabadboy Powder Coating Questions 3 04-25-2005 01:01 AM
Cleaning Oxidized Aluminum With Sand Blasting Media? freematt Other Metal Finishing Questions 2 02-23-2004 02:22 AM
Trouble getting Sand Blasted Aluminum to take color. LogicPB Anodizing Questions 7 06-05-2003 04:42 AM
