I need some advice on how to sand aluminum really fast before polishing it because I do a lot of parts and need to do them quick . The way I知 doing it right now is I usually spray some VHT fast strip on it(On parts were VHT doesn稚 work like on calipers I sandblast them) then I go over with greaseless compound on a spiral sewn with grits 240 and then 400. Once I知 done with that I polish with a sisal wheel that has black compound on it, and then a denim with white compound. The polisher I have now is a セ hp, 3600 rpm that is for 8 In wheels. So if anyone has better ways of polishing please let me know.
Thanks |
that's pretty much it. some places use an industrial sized tumbler that doesn't get great results in some situations.
your method is pretty much it. this is why polishings costs money and is noticed by others, it takes dedication. |
With a vibrating "tumbler" you could do many mid-sized parts at a time, but certainly no faster otherwise. Like the man said...that's why it costs what it costs. |
I bought an air polisher from Chicago Pneumatics. It is absolutely my favorite polishing tool. It turns maximum about 3000 RPM. They make a sander that turns 15,000 and looks just like this but that's too much.
I use it with 3 inch, and one inch, Velcro disks, usually with a little WD 40 or a little water. I made a one inch diameter cookie cutter from a band saw blade to cut the centers out of the 3 inch disks after I have worn them out. The centers rarely get worn at all. I have soft pads about 1/4 inch thick, made by 3M, that fit between the disk pad and the sandpaper if I want a softer sanding surface. I can sand up to 1200 grit with this thing. It saves an enormous amount of work. Of course it doesn't get down into small crevices and such. Richard Last edited by Rasper; 11-23-2007 at 12:50 PM. Reason: more info |
I have one of those to that has 2000 rpm but I think the greasless works better. The only time I use the CP is for deep scaches, I do like the idea with the 1 in sanding pad though.
Thanks |
I bought the pad at a paint store in Santa Rosa, CA, that specializes in automobile paint and supplies. It has a 5/16 female connection so I had to make a little adapter to fit the Chicago polisher. I am in Santa Rosa until Tuesday night; then it's back to Mexico. If you are interested I will find out how you can get one from them. I think I'll go buy another one myself. I was there last week and they had a bunch of them.
Richard |
to know where you can save time you first have to know where you are loosing it . there are many ways to save time but it s different for each part i think speed comes with experience and with the amount of cash invested in equipment and material |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 07:37 PM |
| Sand for blastung aluminum wheels | gtabadboy | Powder Coating Questions | 6 | 08-24-2005 09:04 AM |
| What sand can be used to sandblast powder off aluminum wheel | gtabadboy | Powder Coating Questions | 3 | 04-25-2005 01:01 AM |
| Cleaning Oxidized Aluminum With Sand Blasting Media? | freematt | Other Metal Finishing Questions | 2 | 02-23-2004 02:22 AM |
| Trouble getting Sand Blasted Aluminum to take color. | LogicPB | Anodizing Questions | 7 | 06-05-2003 04:42 AM |
