Old 02-15-2002, 02:17 PM
MDill
Default Polishing bead blasted aluminum
I've got some cast aluminum parts that have been beadblasted (fine glass bead). If I want to polish them will a black compound/sisal combo be enough to smooth things out or should I expect to do some sanding or other heavy removal (greaseless compound).
Matt
Old 02-15-2002, 08:36 PM
mtlplshr
Default Re: Polishing bead blasted aluminum
the cast alum. i've done required some prity heavy sanding to get all the tiny pits out.you can get it shiney with emery but you will have black pits on the surface.the sanding really makes the difference and i think is well worth the effort.
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Dye problems with bead blasted finishes Easttex Anodizing Questions 17 12-14-2004 01:18 PM
input on aluminum polishing and need help choosing a buffer Sid03 Metal Polishing Questions 7 08-09-2004 10:21 AM
Trouble getting Sand Blasted Aluminum to take color. LogicPB Anodizing Questions 7 06-05-2003 04:42 AM
A ? regarding polishing aluminum wheels... geotexZ71 Metal Polishing Questions 4 04-25-2003 08:12 AM
