+ Reply to Thread
Results 1 to 5 of 5
Thread: rpm's ? (sfpm)
  1. rpm's ? (sfpm)
    Is it ok to use a 10000 rpm motor, with a 5" wheel to polish aluminum, the problem is I keep burning motors on hand held polishers, and the guy at sears knows me by my first name. the original polisher I was using was like a 4.6 amp 2600 rpm 1/2 horse. I have burned out 3. so I went and bought a 12 amp 10000 rpm hand held grinder. is this going to hurt anything but myself? I am polishing various bike parts, some have sand cast, and i am knocking them down with 120, 180, 240, then black, and brown
    Share with Facebook
  2. Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,793
    Re: rpm's ? (sfpm)
    It's not hurting anything, but a motor that powerful could handle a much bigger wheel and would get the job done much faster.
    Have A Web Site?
    Share with Facebook
  3. Re: rpm's ? (sfpm)
    very good question.i have used a 2600 rpm with mixed results.it has a lot of hours on it and i am shopping for a new buffer myself.i have just about decided on a 4600 rpm craftsman sander,and am going to make a mandril so i can mount 4 8 inch wheels side by side(will give me about a 3 inch wide wheel)and do some serious buffin.i have met guys who say they use a 10000 rpm grinder but have never seen one used.i have used my buddies 5000 rpm with a cutter wheel and tripoli and it definitely did a faster job than my 2600 did,without worry about catching an edge and pulling my arm off.its a craftsman too but no longer avail.from sears.the 4600 i'm lookin at is like $109 at sears and looks to be heavy duty(it weighs 12 lbs.!)let us know what you end up getting.thanks
    Share with Facebook
  4. Re: rpm's ? (sfpm)
    i tried the 10000 rpm toll way to fast, powerful but to fast, i ended up getting the sander you are refering to the sears 1 3/4 horse 4600 rpm it has ball bearings on motor shaft not bushings, hasnt burt after 5 hours of polishing, so far so good on average the cheaper sears polisher before was lasting an hour went thru 3 of them.
    Share with Facebook
  5. Re: rpm's ? (sfpm)
    Years ago, when I made jewelery, I used an old 1/2 hp washing machine motor with pulleys to increase the speed. If you set it up for multi-sheave pulleys, you can get several speed ratios. Also, some of these motors are multi-speed. Induction motors are quite indestructable compared to the brush-type universal motors, and you can often get them really cheap/free if you ask around. Of course, the pieces I worked were pretty small, so a fixed buffing wheel on a bench was okay. If you have large parts, or need to be mobile, this may not be an option for you.
    fwiw
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. SFPM with aluminum.....
    By Sid03 in forum Metal Polishing Questions
    Last Post: 08-14-2004, 12:07 PM
  2. RPM\'S
    By fosgate99 in forum Metal Polishing Questions
    Last Post: 09-25-2002, 03:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
