mine are direct drives but if i had the choice i would go for belt drive for the reasons you mentioned plus you can upgrade to a stronger machine by changing motor size only.
larger wheels are available through most industrial polishing supplier (sent you a pm about that) 10 inch wheels with a 1750 rpm buffer can get you a very good result with less material wasted then with a 3450 rpm 10 inch wheel .and at the same time running at 1750 with a 10 inch wheel makes it a safer speed and less chances of damaging some fragile parts. |
thanks for the info, baz! the more i research and think about it, the more i think belt drive is the way we should go. i'm going to call around to some local electric motor shops to see if they have any reasonably priced motors that would work for us. anyone have ideas for other sources of inexpensive decent motors?
Len Figure Engineering, LLC |
For motors: scrap yards, junk yards, eBay,(although the shipping can kill you),old window air conditioner units. 3/4 and up single phase motors are generally more expensive than old 3 phase motors. If you have 3 phase power by all means use it. I see 3 phase motors all the time in scrap yards for 25 dollars or less, sometimes a lot less.
Richard |
Len
I just got this polishing machine from Sears. Its a 1.5hp and 8.0amps http://www.sears.com/shc/s/p_10153_1...Bench+Grinders I have not done too much with it yet, but so far it seams REALLY nice. And for only $140 not too bad. But it sure beats the pants off my old Robi 1/3hp bench grinder! (not a suprize there) It is enough of a machine for me as i only polish for "friends". I know that Eastwood offers a large varity in machines (more so than here) so it is at least worth a look. Good luck. Ken |
thanks for the heads up, but that craftsman is really 3/4hp. craftsman notoriously applies creative hp ratings to their products. Some things that help me get the full picture (usually have to tell by the current rating):
Power (in Watts) = Voltage x Current x efficiency (usually assume around .6)= 115V x 8A x 0.6 = 552W conversion: 1hp = 746W 552W/746W = 0.74hp general rule of thumb, you can get around 1hp/10A. if i see a motor that says it draws 15A, i ballpark it without actually working any numbers that it's a 1.5hp motor.
Len, If your near Oklahoma PM me. I'm cleaning house and there are motors laying around.
Gene |
| Industrial blaster and blast room | chromeitout | Powder Coating Questions | 3 | 02-01-2007 10:31 PM |
| Buffer? | EricWil | Metal Polishing Questions | 8 | 05-10-2006 05:39 AM |
| 2 hp buffer | bhhodges | Metal Polishing Questions | 2 | 11-30-2003 07:47 PM |
| industrial flexible shafts | sparts | Metal Polishing Questions | 0 | 05-09-2003 11:41 AM |
| 1/3 HP Buffer | tomg552001 | Metal Polishing Questions | 0 | 03-13-2003 03:19 PM |
