Old 12-19-2007, 01:25 AM
ringblingbelts is on a distinguished road
Default Cleaning help PLEASE????
I have been polishing for many years and have had parts plated after polishing, but my plater has always cleaned my plates for plating. Now I am set up to do my own plating but I cannot get the polishing compound to clean off of the plates. I used the degreaser that Caswell sent me with my kits and set it up per instructions but it simply does not clean the polishing compound.
Is their some chemical I can use to remove the polishing compound before I degrease and activate the parts for palting?
Thanks in advance.
Old 12-19-2007, 05:47 AM
grommit's Avatar
grommit will become famous soon enough
Wink Re: Cleaning help PLEASE????
Hello there,
there are varied methods and products for cleaning items.i personally use acetone in copious ammounts to clean and flush at the same time, using a lint free cloth as to not contaminate the item with fibres etc. the acetone will evaperate eventually.
i have used break cleaner in rattle can as well i have a new kitchen sink brush to get in the intricate areas but the brush isnt harsh to mark the item especially if i am polishing.
have you tried the search facility top right, keep trying typing the key words you think you will need to get your answers, there are a lot of threads out there, Chromo and banditperformance and the guys have given their help in a number of threads.
regards
grommit
UK
Old 12-19-2007, 10:08 AM
Default Re: Cleaning help PLEASE????
Thanks in advance.
Try the plating forum. Or call a plater and ask them. Perhpas some heat would help. I've always used brake cleaner or acetone and had no problem (not for plating tho). What have you used for those many years to remove the compound between steps?
If I'm not mistaken, doesn't plating require a slightly "pickled" surface as opposed to fully show polished beforehand?
Self cleaning Hexhead Oven Building Forum 5 05-07-2007 09:34 PM
Gun cleaning gcastor Powder Coating Questions 12 10-24-2006 05:06 PM
cleaning norsky Powder Coating Questions 1 02-20-2006 08:33 AM
PC Gun Cleaning jbotti1 Powder Coating Questions 4 02-15-2006 08:21 AM
Cup Cleaning garykelly Powder Coating Questions 2 07-05-2004 10:59 PM
