  #11 (permalink)
Old 01-14-2008, 11:38 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Newb questions. Foggy finish. Pimpled/pitted aluminum wheels.
usually sanding a clear coat gives a grey white kind of dust. one way to see if you have a clear on , put some paint stripper and wait a few minutes if you have a clear it will lift off .
if you think the sisal wheel roughs up the part try to skip the sisal .
i don t like using sisal on aluminium anyway.
do not use anything wet on wheels to clean them ,just get a rake or use an old coarse fiber grinding disc to rake the cotton wheel.
yes when buffing the part should get hot ,you need three things to buff , speed friction and compound. you are probably missing on one of those
baz
http://www.polissagepb.com
  #12 (permalink)
Old 01-15-2008, 12:00 AM
posneg is on a distinguished road
So then should I heat up the wheel before I start polishing? I think it might be too cold outside to get the wheel hot by friction alone. Or is there perhaps another method I should use?
And also, so if I had more heat do you think that the scratches that I can still see would be removed because of the added heat?
Thanks.
  #13 (permalink)
Old 01-15-2008, 06:27 AM
Thanks.
It would definitely help if you could get the wheels warm before working on them, even if you have to take them outside to do the actual polishing.
  #14 (permalink)
Old 01-15-2008, 12:17 PM
baz baz is offline
Thanks.
i don t know where you are and how cold it is but heating the wheel will probably help but if it is too cold outside you may still have problems.
just heat alone won t solve everything i have explained the steps you could try in my 2 previous posts
baz
Polishing a Set of Aluminum Wheels...Newbie Detailed Questions fcastro Metal Polishing Questions 13 10-19-2007 07:23 AM
how to fill / fix pitted steel before plating tin/zinc?? MrHeaterbox Electroplating Questions 0 07-13-2007 09:23 AM
Newb with some candy questions..... azoldbill Powder Coating Questions 3 05-01-2006 07:22 PM
Another newb with a handful of questions... garyc2121 Powder Coating Questions 4 12-31-2004 02:32 PM
Powder Coating Pitted Pot Metal batuka Powder Coating Questions 1 05-12-2003 03:44 PM
