Hmmm. i havent tried buffing without sanding yet. I'll give it a go.
I can tell you this though. The pits/scratch marks whatever you want to call them appear in whatever direction you buff the piece against the wheel in. |
Very strange to see this on any kind of steel, let alone stainless. |
i also think it is a bit strange , let us know how it turns out |
I tried buffing without sanding. It did not make any difference at all. What i did do though was i sanded the piece again (well just a small section of it) starting at 80 grit, then 120, 240, 400 then buff and the marks are much less apparent now. What should i be cleaning wheels with anyway?? I usually spray it with wax & grease remover and run a cotton cloth by it which removes all the compound that gets caked onto the wheel during polishing. I live in australia and caswell aus don't have rakes in stock at the moment so what is good to remove trapped metal particles from the wheel |
It looks like it was sanded by hand. If so you should try a good air sander because some times when you sand by hand it looks and feels shooth but its really not all that smooth. From in the pic it looks a little wavy and if you sanded it down a decent amount it would probably fix your problem. Let me know what you guys think.
btw i don t think that using any kind of grease remover on the buff is any good .i think that you could do more damage than anything else Last edited by baz; 01-13-2008 at 01:06 AM. |
I use old saw blades for rakes. You can buy packs of wide jigsaw blades for a few dollars. |
I don't buy rakes. I use sheet steel (22 ga.) and cut little saw teeth in it with snips. It would be better if I made it of thicker metal, and of harder metal, but when I wear one out I just make a new one. Occasionally I hammer the teeth back straight.
Richard |
| Finished my oven--some pics too | nuttyman | Oven Building Forum | 41 | 05-17-2008 05:00 PM |
| Just finished this Masterpiece!!! | cdaeme | Powder Coating Questions | 11 | 04-25-2007 01:37 AM |
| Just Finished | edwardpic | Oven Building Forum | 3 | 02-13-2006 01:34 PM |
| Finished up some wheels-pics | nuttyman | Powder Coating Questions | 2 | 08-03-2005 12:10 AM |
| Pits in Stainless trim-Help! | japr | Metal Polishing Questions | 8 | 05-07-2005 06:30 PM |
