Formax website says: "Glu-Tite is gelatinous glue that is easy to apply to revolving buffing wheels." If you hold it to a spinning wheel like you would compound, does it go onto the wheel...or is it too dried out? I'd like to know if it works... |
not like a paste .if it is a bit dry it might get a bit harder (more spongy rubber like) should be used on a buffing wheel when the wheel is new . if you have variable speed lower the speed to avoid getting the whole tube of glue on the wall .if no variable speed (like me) i switch off the buffer and apply the glue at the same time . let me know how you like working with the stuff . i tried couple of times and did not really like it , maybe i should hve tried longer |
um, i got a solid brick of rubber. *SOLID* i cut the cylinder cross sections throughout the length, and there is no sign whatsoever of anything remotely "gelatinous". oh well!
Len Figure Engineering, LLC |
Is it harder than the greaseless itself? That's pretty hard but it does go onto the wheel OK. |
the picture of the glu-tite tube open on a website looks like what i got... kind of a sponge-looking texture. i sure wouldn't describe it as "gelatinous." i'll give it a go.
