I've tried sandblasting, but it is very slow too with my sandblaster. I can't strip chemically because it will attack the zinc in the part. Any suggestions? Vitals new 8x1/2 sisal wheels, raked to eliminate loose pieces. 1 HP bench grinder |
120 or 240 Greaseless will strip the chrome much more quickly than emery, with its approximate 600grit equivelent. However, you must follow up with progressive grit compounds to get the finish smooth again.
Maybe you are not using the greasless properly because 80 grit is more than enaugh to remove chrome plating. You have to built a head of greasless on your 1/4" spiral. let it dry for at lease an hour. The best way to work is to use 4 wheel mounted on 2 two sided bench grinders. When the head is starting to where off put some greasless on it and go work on anothere wheel. That way you never stop and always working with dry greasless. Always remember not to where out completely the head of greasless because it's not going to have enough time to dry.
hope this will help |
Thanks for your reply. You might be on to something. After I apply the greaseless to the wheel I only waited about 30 seconds. When I stop the wheel, I see that the wheel is covered with compound and red all over the face. It certainly feels dry to the touch, but maybe its not. I thought I read from the manufacturer that it can be used immediately
Yes, sorry I did misread your post, I was tired this morning. I agree with internet, but you shouldn't have to let it dry for an entire hour. 15 minutes would be good, depending on atmospheric conditions.
inevr try to remove chrome by blasting or sanding on aluminium parts .
in my opinion it is a complete waste of time , waste of material , and like NOL4154 says it will deform and damage aluminium any chrome parts that needs to be stripped i let the plating shops take care of it |
| triple chrome vs. nickel/chrome vs. copy chrome | spectraflamed | Electroplating Questions | 4 | 01-21-2007 11:07 AM |
| copy chrome vs triple chrome plating | splbnd27 | Electroplating Questions | 18 | 06-21-2006 08:35 AM |
| Pros and Cons between CopyChrom and Triple Chrome | Jezella | Electroplating Questions | 0 | 01-29-2005 06:56 AM |
| Removing the chrome surface from aluminum based auto trim | jbashaw | Metal Polishing Questions | 6 | 10-01-2003 11:20 PM |
| Hard chrome vs triple chrome | butters | Electroplating Questions | 1 | 02-20-2003 12:35 AM |
