Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
  #11 (permalink)
Old 01-28-2008, 07:20 PM
95gts is on a distinguished road
Default Re: Is There A Better Way To Remove Tarnish From Nickel?
I have never used vinegar....Vinegar is a oxide from wine, so its a effective cleaner...anyone that has a peice of metal, try to use vinegar mixed with table salt...That should also remove oxidation from CU?AG alloy...A Ni alloy you have to test it on...
Need something stronger...Try lemon juice then vinegar and salt solution...even cigarette ashes mixed with water will clean non ferrouse metals well...
  #12 (permalink)
Old 01-29-2008, 07:17 AM
Good to know...although personally I'd just buff it off...
Closed Thread
Copy chrome and resistance to rust, tarnish, dulling? phunkmastakrez Copy Chrome Kit Customers Only 6 08-25-2005 10:13 AM
Tarnish or Corrosion of Copy Chrome Westy Electroplating Questions 2 08-23-2005 10:43 AM
Golf Clubs - How to remove nickel finish prior to refinishin doctordave Other Metal Finishing Questions 3 06-03-2005 04:21 PM
Silver plating and rapid tarnish rustydog Electroplating Questions 0 04-15-2003 03:43 AM
copy chrome tarnish? bellows01 Electroplating Questions 3 01-15-2003 02:50 PM
