how is it possible ? i have been doing polishing for i think 18 years as a full time business plus a couple more years before that as a side job . i do a couple of carbs for harleys every month , i can tell you that i have a dozen of different die grinders , 1/4 inch belt sanders , air files ,sanders but when i do a carb all i use is a die grinder and the finl buffing on one of my buffing machine. it is normal that if it is your first carb it takes forever to do but the next one should be faster and with time you will get faster and if you are serious about polishing you will get better tools and then after many years you will be laughing at how long it used to take to do a part . here is what i do in 7 or 8 hours ( that is if i am not disturbed by customers every 5 minutes) |
btw SnS is a company that fabricates high perf parts for harley davidsons from carburators to engine cases ,cylinder heads and complete motors
Thanks Baz for the tips and encouragement. I plan to get more and better equipment as I go, and expect that I will need 20x what I have before I can plan on this being a serious part time business. That cylinder looks great too.
Also, I knew S&S makes Harley hi-po parts etc, thought I remembered an "S&S" kit where a 40-44 mm mikuni crab was used with their intake etc. I was trying to get a grasp on whether the carbs you polish in about 90 min are slide type ro a butterfly pumper type, but for polishing time I guees it make little difference. I would expect familiarity does make a difference. As such I am starting a separate log of parts, issue encountered and remedies for my reference. Thanks again, James |
and yes familiarity does make a difference the more you do the faster you will get . one small trick to go faster that i still use after many years is to take a minute to look at the part and visualise how i will proceed Last edited by baz; 02-05-2008 at 01:13 AM. |
Len Figure Engineering, LLC |
Hey baz, did you ever see anything about S&S voiding the warranty on engines and carbs that are 3rd-party polished? Seems to me there was actually something on their website at one time, and I'm pretty sure a custom bike builder I know told me the same thing. Something to do with getting grit in the assembly, and also loss of cooling capacity with polished fins on the engines (i.e. polished = less surface area).
and even after being warned that abrasives will hide everywhere possible , well they still put back the heads on the bike without taking them apart for final cleaning, and guess what, they tried to blame me a while later because they had to strip the motor apart for a rebuild. i am doing an engine case today and i told the customer that i m am not responsible for him leaving the bearings in |
| Minimum charge | FERmidable | Powder Coating Questions | 2 | 01-10-2008 10:46 AM |
| How much should I charge? | FiReBReTHa | Powder Coating Questions | 3 | 05-24-2007 08:09 PM |
| how much do you pros charge? | alabama_lowlife | Metal Polishing Questions | 6 | 11-22-2006 06:25 PM |
| what would someone charge for ? | boucher | Powder Coating Questions | 2 | 03-25-2005 10:52 AM |
| What to charge? | txturbo | Electroplating Questions | 9 | 04-30-2003 09:43 AM |
