Buy One, Get One Free Buffing Wheels
Old 02-07-2008, 04:32 PM
quadracer2cool4u is on a distinguished road
Default What kind of sanders should I buy?....
Right now I'm using a 3" 2000 rpm velcro air sander and greasless compound to sand the parts before polishing. I'm intrested in buying some more sanders that would save me some time, I was thinking of buying another 3" velcro air sander that has 2800-16000 rpms and also comes with a 1 1/2 inch backing pad. I do alot of brake parts for atvs so somthing that can get into the nooks and cranys would be great. Do any of you use tublers? if so could you give some specs on them? What do you guys think is the best way to do paint stripping? should I just bead blast? Any input would be great!!!
Thanks and have a great day!!!
Old 02-07-2008, 10:38 PM
baz baz is offline
baz will become famous soon enough
Default Re: What kind of sanders should I buy?....
well not everyone does the same kind of parts or work with the same tools ,
but i think a 1/4 inch angle die grinder is very useful and if you can make or have someone do some adapters you can use it with cartrigre rolls , buffing wheels ( 3 inches and smaller) sanding pads and more.
stripping paint : sometimes easier and faster just to blast and sometimes i use paint stripper .
baz
http://www.polissagepb.com
Old 02-08-2008, 10:53 AM
I saw on one of the threads you posted and you said soming about using a 1/4 inch belt sander. Where did you buy it from? cause I was neaver able to find one that sounded good. Where do you buy the belts? How fine in grits do they go? What do you use on the angle die grinder?
Thanks
Old 02-08-2008, 12:17 PM
baz baz is offline
Thanks
different company make the belt sanders but mine is a dynabrade they are expensive but it is quality stuff.http://www.dynabrade.com/
belts you can get from most major abrasive places , (norton ,3 m , and others)
for the die grinder i already answered that question . reread my previous answer
baz
Old 02-09-2008, 04:48 AM
justme102 is on a distinguished road
You use air tools?
How big is your compressor?
I use primary electric tools from pferd and suhner.
Old 02-09-2008, 11:25 AM
All I use is air tools, if you have any suggestins in electric tools let me know. I have a 80gal air compesser that has about 14 or 15 cfm @ 90 PSI.
Old 02-10-2008, 02:19 AM
I think about to buy the UBC 10-R belt grinder from suhner.
www.suhner.com
There is also some auxiliary equipment available, like different trolley poles. The belts are available from suhner too, or as baz said.
The UBC is expensive, but i think i need a new toy to get faster and to get forward.
I thought about air tools some time ago. But i didnt have enough space for setting up a big compressor. And there is also the noise that it makes. I think my neighbours would kill me...
  #8 (permalink)
Old 02-10-2008, 10:01 AM
jrow is on a distinguished road
quadracer2cool4u,
I hope you guys are aware that "Baz" has been in the business a long time and he knows what he is talking about.
I'll give you this advise. "Don't make things more complicated than they are"! If you have a piece of aluminum that doesn't have scratches in it that you can catch with your fingernail, just polish it.
They make flap wheels of all different diameters and grits, get one that will fit in the area that you need to sand, if you need to sand. The little nooks and crannies can be sanded with Cratex or using some of the Dremel products. You can use greaseless compound on buffs that are any place from 1" in diameter or larger.
As far a curb rash goes, you want to sand with something big enough in diameter that you don't leave waves in the wheel edge.
As "Baz" recently stated look at the piece you are going to polish and form some kind of plan that you will use the least amount of labor and material to accomplish what you want.
John
  #9 (permalink)
Old 02-12-2008, 10:45 AM
FigureLLC's Avatar
Caswell Platinum Member
FigureLLC is on a distinguished road
John
it only took one look at his website to convince me! (...actually, i was convinced before that.)
Len
Figure Engineering, LLC
  #10 (permalink)
Old 02-12-2008, 11:09 PM
baz baz is offline
stop that you guys ,the only reason i m good is that i practiced for a longer time
oh , another reason :most of my customers are harley owners and are much taller than me so i have to make sure the part is up to their specs
baz
Detail Sanders tbreaden Metal Polishing Questions 4 12-29-2007 09:53 PM
3/8" wide sanding belts for air belt sanders Quadracerrule Caswell Please Sell This... 0 10-20-2007 01:17 AM
Belt Sanders mpierich Metal Polishing Questions 2 01-08-2006 02:56 PM
Sanding Belts, For Belt Sanders knife_man Caswell Please Sell This... 0 11-29-2005 04:13 PM
What kind of plating ilikevelos Other Metal Finishing Questions 5 11-01-2002 08:40 AM
