Old 04-29-2003, 07:46 PM
tbloss001
Default Satin finish without bead blastin?
Is there a way to create a nice satin finish on brass, without bead blastiin?
I have a buffer and wheels, but no sand/bead blaster.
Thanks for any info.
Todd
Old 04-29-2003, 09:41 PM
marsfrogie
Send a message via AIM to marsfrogie
You try a scotch brite pad? Greaseless compounds will work, but they will make the finish a bit uneven. A wire brush will give you a brushed finish.
Old 04-30-2003, 01:51 AM
tbloss001
Thanks for the tip. I'll have to check my local shop and see if they have wheels made out of that scotchbrite stuff (I assume you mean the green scrub pad).
I know I can get a uniform brush finish with my wire wheels; I chuck a wire brush wheel into my drill press and using the drill press' baseplate as a level guide, run the piece against the horizontaly spinning brush, while raising and lowering the drill bit with the press handle. It works pretty well, but I'd really like to be able to produce that universal satin look you can get with the bead blaster.
t.
Old 04-30-2003, 03:02 PM
mcaswell's Avatar
Caswell Inc Founder
We sell these, called Brightex wheels.
See http://www.caswellplating.com/buffs/brightex.htm
Have A Web Site?
Old 06-21-2003, 07:32 AM
danman
fill your mouth full of sand and blow really hard.
Sand or bead blasting Q sorry, im a noob just starting Paintbalaguy Other Metal Finishing Questions 3 07-19-2005 10:20 AM
Newbie, trying to find best way to finish aluminum-LONG POST chik Metal Polishing Questions 6 03-14-2005 09:11 PM
Dye problems with bead blasted finishes Easttex Anodizing Questions 17 12-14-2004 02:18 PM
how to create a satin finish on gold plated material didierphmartin Electroplating Questions 3 11-15-2004 03:00 PM
how to get a nice satin finish???? help customandsound Other Metal Finishing Questions 9 06-03-2004 09:02 PM
