WoodMotorsports,
From the information I see the 3m Scotchbrite EX2 is a hard wheel which would load up if used on aluminum. The Norton Bear Tex would be a better option as would flap wheels. John |
the ex2 i hav not tried but from what i read on it i would never try that on aluminium .like jrow says its a hard wheel and it will load up. plus being that hard
will probably do more wrong than good on aluminium. bear tex on the other hand i have used and i still use in some cases , they do wear down quite quickly but if you get them for free ,then it s not a problem . i have one of those 6.1 intake to do next week, and from the last one i did i know thy take lots of work to do but they have a very nice shine once done . word of advice : the casting on those is rough so you have a good quantity of material to remove but if you remove too much then the porosity will start to show so when the rough surface is smoothed out , stop there and don t over do it , |
Thanks all for the info. I got my first order from Caswell today, and another arrives on Friday. (ordered to soon without studying enough)
I've got greaseless compounds so I'll go that route and sandpaper rather than using the 3m wheels. I've already been practicing on just about anything aluminum with what I had on hand, so all my old air tools are gleaming right now. |
and also when trying to get a brushed or satin finish on aluminium and stainless steel it is very good |
| What is the best way to remove cast marks from cast aluminum? | x1rider | Metal Polishing Questions | 6 | 02-17-2007 01:06 PM |
| cast aluminum prep. | boston_jake01 | Powder Coating Questions | 3 | 11-09-2006 06:28 PM |
| Aluminum prep for chrome plate | jm | Metal Polishing Questions | 1 | 02-02-2004 01:24 AM |
| Cast iron prep | ewmorritt | Metal Polishing Questions | 1 | 05-28-2003 01:31 AM |
| Aluminum Wheel prep and polish | patrickzeus20 | Metal Polishing Questions | 2 | 03-04-2003 01:00 PM |
