Bang for the buck
Hi I just wanted to pass on to others...well if you are buying compound and buffs at hdwre store(as I was)-you are overspending.
Not only is the compound better cutting, faster finishing, and easier to use-it is abetter value, you get a lot more for your money from Caswell.
Same with the buffing wheels. Also, I have yet to see any vented, sisal or domet buffs in hdwre stores.
Personally, I like the sisal on thick rough alum castings-it really saves time. I have yet to use the vented, but a test showed it ,too, cut quick. So, ocassionally we may have to grab a wheel locally, but as soon as you can place an order with Caswell, you will see your results much quicker, or at least I have.
Thanks, James
