Old 03-16-2008, 11:03 PM
Caswell Platinum Member
samtgallagher is on a distinguished road
Default question on another motor/flex shaft
i was looking at a few options along with the industrial flex shaft, and this is what i have came up with.
flex shaft from caswell, $400~
item#1 from eastwood $175~: http://www.eastwoodco.com/shopping/p...roductID=16443
item #2 from eastwood $350~: http://www.eastwoodco.com/shopping/p...iProductID=853
my question is, that item #1 and #2 both run 1/3 hp. item #2 looks like is is made for wheels, but item #1 can be fitted with a 1/4" shank, which can be used on an adapter for a wheel.
with that being said, motor on item #1 looks the smallest, even though it's the same hp, and also turns high rpms. would item #1 be able to turn a 6" wheel without straining it alot?
Old 03-17-2008, 01:49 AM
baz baz is offline
baz will become famous soon enough
Default Re: question on another motor/flex shaft
i would not use item #1 to run a 6 inch wheel , the motor will probably have a hard time with the 6 inch wheel , and i would think that the small diameter of the shaft woud not handle the torque needed towork with a 6 inch wheel
baz
http://www.polissagepb.com
Old 03-17-2008, 06:27 AM
Number 2 is just a glorified Dremel - you'd burn up the motor and that little shaft would twist up like a pretzel if you tried to use a 4-6" wheel.
Number three looks OK, except they don't tell the length (and it looks short to me). By the way, you'll notice the wheel isn't spinning in that pictue. You can't bend the shaft that much and have it last very long!
Old 03-17-2008, 10:03 AM
jrow is on a distinguished road
samtgallagher,
Either way you go there are pro's and con's. Personally I would prefer to use something with a collet in lieu of a Jacobs chuck. The collet is normally smaller and easier to get into tighter areas.
John
Old 03-17-2008, 12:45 PM
baz baz is offline
what am i missing here ?
i have only 2 links one for #1 that is like you say a glorified dremel with a skinny flex shaft , wich i would never use with anything close to a 6 inch wheel
then the second link for # 2 wich looks much bigger but like you say they don t say anything about the lenght of it
baz
Old 03-17-2008, 03:41 PM
John
That's a good point, John. I think you could make or buy an attachment so you could chuck a 4"=6" shaft into a regular chuck that would have a collet on the end of it. That way you'd have the best of both...the chuck could handle a 1/2" mandrel if you wanted.
Old 03-17-2008, 09:13 PM
i don't know about all this ****, i may just end up buying that 3/4 hp buffer and flexshaft from caswell. i hate ot risk ordering a $200 one from eastwood, and it not work well, or break a month down the road.
Where to get spacer kit for Baldor motor? bradnailer Metal Polishing Questions 2 10-22-2007 08:19 AM
motor housing speeddemonrodsteration Powder Coating Questions 2 08-20-2006 11:54 AM
Motor cycle wheel tavo1765 Powder Coating Questions 6 03-17-2005 10:44 PM
Buffing speeds & flex shaft? Tallman Metal Polishing Questions 2 06-13-2004 12:19 PM
flex shafts shine Metal Polishing Questions 4 11-08-2003 01:54 PM
