Here's the info found on eBay...
18lb VIBRATING METAL POLISHER Thumlers Tumbler UV-18 You are bidding on a fantastic, BRAND NEW IN THE BOX , heavy duty 18 lb. Capacity THUMLERS Ultra-Vibe Vibratory METAL POLISHER. (Model No.180, UV-18 ) That's right this tumbler will hold up to 18lbs of metals at a time for you to polish. This tumbler is great for polishing most metals to a nice shinny finish. It's works very well for shell casings, coins, fishing lures, jewelry, brass, silver and lots more. (not recomended for rocks) It is a super strong heavy duty, professional quality vibrating tumbler. This features a continuous duty, large 1/30hp motor with overload protection. It has a removable Heavy Polyethylene Bowl that measures 8 3/8 inches by 4 3/8 inches with Lid and Vibrates at 3000 VPM. The Mass creates a cyclonic effect, moves around the bowl and down into the center. The base is all metal, not a plastic toy type like other companies make. Extensively used by serious hobbyists, laboratories, and schools for an unlimited variety of tumbling and mixing operations. This tumbler will last you a long time as Thumlers Tumblers are considered the best in the business. ![]() |
I've been struggling with trying to polish some emblems that I've made to a perfect mirror finish. Having done some research on here, I think that the finish I've been getting on this soft aluminum emblem is probably the best I can get. Here's a sample:
![]() Someone pointed the product above as a possible solution and wondered if anyone has any input or experience using a vibrating metal polisher? Sounds too good to be true, and the thought of being able to get something to a decent point to throw into something like this is very tempting. Any thoughts? |
It's not their Industrial model, just the hobbyist model, so be careful if you plan on using it a lot. It also looks dusty and used in the picture.
We sell their industrial model at http://www.caswellplating.com/buffs/...y_tumblers.htm
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm |
destroyer125,
Will a tumbler smooth out a sandblasted finish enough to polish it with out having to use a air sander? I need it for atv engine covers, brake calipers.... Thanks alot!!! |
Does anyone know where I can find examples of polished aluminum parts done this way? I can't help thinking that this solution is too good to be true- it sure would save me a lot of aggravation to be able to "cheat" with one of these! |
I wouldnt call them to good to be true......Yeah, you can yield the results you want with one....but you can also mess up your stuff with one.
I been running large vibes and tumblers for jewelry finishing for years. For small ALU parts, I use crushed walnut shells for cutdown (this stuff by nomeans is considered a heavy cutdown media but in the tank for a few days it will remove light scratches from alu) For a bright polish I use corncob/sawdust mix with polishing paste..........FYI this makes a big mess^^ If you are wanting to polish solid ALU parts, Not sheet or parts with thin iteams on it, You can use a small sized steel shot, the shape I use looks like a ball with a ring around it (looks like a planet). Keep the shot clean because if the shot is dirty, your pieces will be. |
| my new polisher | Rasper | Metal Polishing Questions | 3 | 01-21-2008 08:54 AM |
| some thoughts on polishing stainless | Rasper | Metal Polishing Questions | 8 | 01-11-2008 09:30 AM |
| Thoughts on using a commercial pizza oven to bake powder coated parts? | Badger | Oven Building Forum | 2 | 10-08-2007 04:59 PM |
| y polisher use for metal polishing aluminum? | turbotim23 | Metal Polishing Questions | 1 | 04-24-2006 12:28 AM |
| what polisher? | chiliuno | Metal Polishing Questions | 8 | 09-26-2004 07:35 PM |
