+ Reply to Thread
Results 1 to 4 of 4
Thread: polishing glass
  1. #1
    Default polishing glass
    I am a kiln-fired glass artist. When I fire glass in a mold, the surface touching the mold surface is matte-to-rough, which I want to polish to a shine. I am totally new to buffing and polishing, but think this may be the solution to my problem. What I need to know is what compounds would be best to use on glass to (1) remove the rough surface, and (2) buff the glass to a high shine. Also, I have a bench grinder - can it be used for this process, with the right wheels and compounds? Thanks for helping a newbie!
    Share with Facebook
  2. #2
    Join Date
    Jul 2005
    Posts
    495
    Default Re: polishing glass
    Quote Originally Posted by rlandersn View Post
    I would think you would be better off polishing your mold prior to forming the glass. Is this possible? What is your mold made from?
    Try this: http://www.facetingmachines.com/polishing_glass.shtml
    John
    Share with Facebook
  3. #3
    Join Date
    Apr 2007
    Location
    Adelaide, Australia
    Posts
    247
    The link provided by jrow is pretty much spot on. First grind with wet and dry paper ensuring you regulary rinse then machine polish with cerium oxide mixed with water. If the parts are small I'd use a dremel tool or equivalent with a felt buff. I'll check with the glass shop guys here for other faster cut componds. (we do precision optics).
    Cheers
    Mark Smith
    OK, the cheaper and possibly more readily available compond is to simply mix clay (potters clay works fine) with water. As with the cerium oxide, the more solids you mix in the faster the polishing cut. The less you mix in the finer the polish.
    Share with Facebook
  4. #4
    Join Date
    Aug 2004
    Posts
    957
    If molding glass is a common practice, what do the other artists do?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Need Electroplating Onto Glass
    By michaelvall in forum Services Offered/Wanted
    Last Post: 12-18-2007, 02:22 PM
  2. Illusion on Glass? Any one tried it?
    By chromo in forum Powder Coating Questions
    Last Post: 09-16-2007, 11:46 PM
  3. glass bead have zinc?
    By hefrod in forum Electroplating Questions
    Last Post: 09-23-2005, 08:15 PM
  4. glass blasting
    By berndog in forum Metal Polishing Questions
    Last Post: 08-24-2005, 09:33 AM
  5. sandblasting--sand or glass?
    By craigcraig in forum Powder Coating Questions
    Last Post: 07-10-2004, 11:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
