Buy One, Get One Free Buffing Wheels
  #11 (permalink)
Old 04-10-2008, 12:13 PM
baz baz is offline
baz will become famous soon enough
Default Re: Sanding Tips, Tricks & Secrets
Originally Posted by mpierich View Post
Baz might use buffing compound if he's found it works, but normally you'd use a high-speed grinder's grease (available here at Caswell). It really is amazing how much smoother the rolls cut with grease, and I've found they cut faster and last longer as well, and it helps keep some of the dust down as well.
yes i use that grease too (well the one i m using looks more like a hard wax), but when i m done with the 320 with the grease i go over the area with polishing compound on top of the used 320 roll takes 2 minutes and it makes a little easier to buff after.
baz
http://www.polissagepb.com
  #12 (permalink)
Old 04-10-2008, 01:08 PM
Not a bad idea...you're gonna give away all your secrets if you stick aroud here long enough!
  #13 (permalink)
Old 04-10-2008, 10:56 PM
quadracer2cool4u is on a distinguished road
mpierich, can you post the link of the grease that you are talking about. Witch type do you recomend?
Thanks!!!
  #14 (permalink)
Old 04-11-2008, 01:16 AM
baz baz is offline
don t worry i could do this for a long long time and still hae a few aces up my sleeve. remember i been doing this for over 18 years
baz
  #15 (permalink)
Old 04-11-2008, 06:12 AM
Thanks!!!
Look here: http://www.caswellplating.com/buffs/compound2.html
Use the F-10 for high-speed stuff like cartridge rolls; use the F-26 for slower sanding belts, etc. DO NOT use the F-10 for slow speeds...it'll put a glaze on the abrasive that ruins it and is tough to get off even with a belt cleaner.
  #16 (permalink)
Old 04-11-2008, 02:38 PM
Smile Re: Sanding Tips, Tricks & Secrets
Thanks for the info!! I'll check it out some time.
sand blasting cabinet...relocated to tips n tricks section duke Powder Coating Questions 15 12-30-2007 11:28 AM
Tips and Tricks non-stick Powder Coating Questions 27 11-11-2007 02:01 PM
I have 3 tips with my new gun.Which one do i use JasonH Powder Coating Questions 2 05-24-2005 10:36 AM
Tricks to minimize outgas? tomg552001 Powder Coating Questions 19 01-07-2004 09:15 AM
20 Silvachrome tips and tricks polygon Other Metal Finishing Questions 4 06-02-2003 08:29 PM
