Old 05-09-2003, 08:33 AM
sparts
Default flexable shaft polishing
is there a flex shaft that has the power to polish with a 3" working surface without getting ripped from your hand? the part will be mounted in a vise and will be starting with a vib finish and have to go to a mirror ,flawless finish.
Old 05-09-2003, 10:01 AM
marsfrogie
Send a message via AIM to marsfrogie
You shouldn't have any problems with the buff getting ripped out of your hand if you buff the edges with the wheel spinning towards the inside of the part. As for using 3" wheels, caswell's arbor shaft should work.
MOTORCYCLE POLISHING 101 CLASS IS IN SESSION! NautiShine Metal Polishing Questions 61 05-15-2008 02:03 PM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Fine polishing with the Flexible shaft grinder c_gismo Metal Polishing Questions 3 11-27-2003 12:14 PM
Dimensional influences of Brite Dip Polishing Aluminium whistule Metal Polishing Questions 0 10-03-2003 08:40 PM
Brand Newbie Aluminum Polishing Question gdsegel Metal Polishing Questions 1 04-25-2003 08:04 AM
