Old 04-21-2008, 02:38 AM
alloywheel is on a distinguished road
Question polishing as-cast aluminum wheels
Hi
I intend to polish 100 Alloy Wheels as following images:
(Image of the wheel after leaving the mould, and not machined), and the surface is coated with a clear layer of polyester.
Considering the number of wheels and polyester coating on it,
what kind of polish do you suggest?
And is it possible to do the polishing manually?
How long does it take to polish the hooding?
I intend to polish the spokes only.
The size of the wheel is 13x5"
Old 04-21-2008, 01:33 PM
jrow is on a distinguished road
Default Re: polishing as-cast aluminum wheels
alloywheel,
Yes it's possible to polish the 'hooding' on your wheel manually. After the machining work is done, you will have to remove the polyester paint/powder before you start to polish.
How rough the surface is would determine what grit of sandpaper you would start with.
Check this thread out and then ask your questions. MOTORCYCLE POLISHING 101 CLASS IS IN SESSION!
What kind of polish are you looking for? The time it would take would be based on your experience level or how long it takes to become proficient!
John
Old 04-22-2008, 01:04 PM
Thanks,john
I ask my questions of this thread out
Polishing Cast Aluminum nikos8 Metal Polishing Questions 9 04-04-2007 01:33 PM
cast aluminum wheels....pitting! how to get it out? will they come out? soccergk Metal Polishing Questions 8 03-23-2007 06:05 PM
Polishing cast aluminum turbohardtop Metal Polishing Questions 26 07-05-2005 10:10 AM
ok! cast aluminum polishing Carcher7878 Powder Coating Questions 4 05-20-2004 09:53 PM
Cast Aluminum polishing? Neons4life Metal Polishing Questions 4 02-01-2004 02:45 PM
Powered by vBulletin® Version 3.7.0
