Old 05-13-2003, 02:09 AM
jhearn
Default Question about buffing speeds
On one of the Caswell links I read that the recommended speeds in surface feet is 3500 to 7200. For green compound on stainless (thin car trim panels) using a 10 inch soft, cotton wheel, which would be a better speed: 4300 sf or 8500 sf? In other words, is the 8500 sf too fast for some reason? I wouldn't have thought so but after reading the above recommendation, now I'm not sure.
Old 05-13-2003, 03:42 PM
marsfrogie
Send a message via AIM to marsfrogie
Yes you would want to use the lower buffing speed to reduce the risk of warping the piece.
Old 05-14-2003, 12:55 AM
jhearn
The trim I am polishing is from a 1954 car so it is reasonably thick and not too subject to warpage. I thought heat was my friend in polishing so if the piece warmed up a little so much the better. Also, it is a soft cotton wheel so the pressure on the wheel will be minimal. Thanks for the previous post but I guess I'm just amazed that 3400 rpm spindle speed and a 10 inch wheel are too much.
Old 05-14-2003, 08:18 AM
marsfrogie
You should be fine then. I use 3450 spindle speed with 6 to 10" buffs and it all works fine for me.
Buffing speed question berad001 Metal Polishing Questions 3 03-11-2005 09:55 PM
Buffing speeds & flex shaft? Tallman Metal Polishing Questions 2 06-13-2004 12:19 PM
"optimal" wheel speeds skiddz Metal Polishing Questions 0 01-27-2004 02:29 PM
A question for the anodize boys from the powder guy non-stick Anodizing Questions 3 11-26-2003 04:22 PM
buffing direction hue Metal Polishing Questions 2 02-23-2003 10:28 PM
