I know this isn't metal, as per the forum title, but.... there is no "other" polishing forum. Next best thing ^_^
In my awesome lack of attention to detail, I filled up my glass cleaner bottle with wheel acid. Which is basically Hydrochloric acid & some other kind of acids which I am too upset to think about at the moment.
WELL long story short, went and sprayed down the windshield of my car - you know, the only window that *really* matters, and I realized about 30 seconds into it, that.. that's not the glass cleaner smell, that's the smel.. OW my hands are burning.
So yeah, rinsed it all off, and it has left a nice etched surface on the glass. It's still transparent, but OMG I can't wait to see how bad it is when the sun is actually out.
____
Other notes:
I have used wheel acid *dozens* of times to remove water spots. It works, and works GREAT I might add. In fact to calm down, I did the same thing to my mother's truck windshield since I was out there at the house, and it worked great. My car is just... well, old. And old glass = pitted, and that = trouble with acid.
________
My big question of the day is, will Caswell's glass polishing kit work to get rid of the etched surface on the glass? I have used similar setups for removing light scratches (worked as a detail tech for a while there, but never ran into this before). I'm sure that it'll work, but before I spend the near $30 to "try" it I would like a second opinion first.
The glass was needing a good polish anyways, there are plenty of light pits and water spo.. well not anymore, but it needed it none the less. ^_^
Can somebody give me an alternative to try? The etch isn't that bad, it just looks like a light haze all over the window. I tried some Mothers Mag polish, in an attempt to see if it was just surface oxidation that could be removed. It's not - it'll have to be polished off with Cerium.
Any thoughts?
I understand how it works and all that, I just have no experience in polishing the glass with a felt bob to this extent. I've only ever used the soft microfiber pads & cerium powder in an effort to remove water stains. Nothing this major, and certainly never something this etched.
Please help!?
LinkBack URL
About LinkBacks
