Old 06-20-2003, 10:11 AM
Randelle
Default Thought I did everything right...
...but it came out like ****.
I am polishing the crankcase cover from an 84 Magna. I did a section with just a spiral wheel and emory compound, then a buff with tripoli and it came up like a mirror, it just had ridges in it. I ordered some stuff from Caswell and decided to try the large area with "Honda" in the center.
I started with 320, then 400, 600, and finished with 1000 paper, all wet using a good sanding block, and I changed directions 90^ after each grit. At this point the piece looked good and had a nice, even finish; quite attractive actually. I then used a treated spiral sewn wheel with emory then a treated buff with tripoli, then a loose buff with polishing compound, Mothers polish and finished with wet corn starch. The part looks kinda cloudy and just doesn't have a chrome like shine. It also looks like there are tiny, miniscule pits and some even look like tiny perpendicular scratches.
The only thing I can figure is that I should have sanded in the same direction each time I went up a grit, but I would think that the emory compound would have taken out the tiny scratches. I have some greasless 240 and a sisal wheel, should I start there? The area beside it came out nice though when done as I described in the begining, other than the lines. Is it just bad metal?
Please help,
-Randy
Old 06-20-2003, 09:19 PM
marsfrogie
Send a message via AIM to marsfrogie
You probably just missed the pits in the sanding process. You shouldn't have to sand past 320, just use emery. Spend more time with the white on a spiral sewn or loose cotton wheel. White will remove the haze.
gols plating solution gone bad?????? clocktools Electroplating Questions 10 04-08-2008 10:09 PM
Anyone ever thought of or done this? Bud Powder Coating Questions 7 06-19-2005 03:32 PM
Picture of my work..thought i'd share tomg552001 Powder Coating Questions 3 10-24-2003 11:57 AM
