If you have the muscle to hold a wheel up to a machine, and the wheel is very simple, you could possibly do much of it on a buffing machine.
I don't think you really did much of a search...here's greaseless compound and it's only a click or two away... Caswell Inc. - Standard Buffing Compounds Go to the bottom of the page. Also, Google is your friend for more info. Instead of grease as the matrix holding the abrasive, greaseless has coarse abrasives embedded in a rubbery water-based material that has to dry on the buffing wheel before you use it.
LinkBack URL
About LinkBacks
