Old 06-23-2003, 07:14 AM
pro 100
Default polishing engine components
i would like to polish my engine components
- front timing plate
- inlet manifold
- etc
i'm new to this game, is there a complete kit available for such a task?
what do you recommend to be used, taking into consideration they are cast items?
Thanks
mmmmmmmmmmmmmmmm.................................. ....................................... i like dat shine
Old 06-23-2003, 11:32 PM
marsfrogie
Send a message via AIM to marsfrogie
At the bare minimum, you will need the following:
-240 grit greaseless compound with a spiral sewn wheel.
-Emery compound with sisal wheel.
-Tripoli compound with spiral sewn or loose cotton wheel.
-For added luster you can use white compound on either a spiral sewn or loose cotton wheel.
For the intake manifold, you will need an assortment of felt bobs. Sanding tapers will make your job much easier on the intake manifold. I do not believe Caswell stocks them, but perhaps they could special order.
Old 06-24-2003, 02:08 AM
pro 100
Default polishing
Thanks for that
much appreciated
T
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
Polishing cast aluminum motorcycle engine cases. Mutt Metal Polishing Questions 1 07-16-2005 11:46 PM
PCing engine components... dansilbaugh Powder Coating Questions 2 06-10-2005 10:28 PM
Motorcycle Engine polishing tomlando Metal Polishing Questions 6 01-17-2004 03:28 PM
Polishing Aluminum (Engine intake) RyanT Metal Polishing Questions 3 02-25-2003 07:53 PM
