Old 06-23-2003, 07:16 AM
pro 100
Default aluminium welds
i'm a fabricator
- manifolds
- intercoolers
- inlet plenums
- etc
now because i TIG weld these components, you can still see the join of the two sections quite clearly
are you able to grind these down, polish up and make it look like it is one complete sheet?
any ideas?
Thanks
mmmmmmmmmmmmmmmm.................................. ....................................... i like dat shine
Old 06-23-2003, 11:30 PM
marsfrogie
Send a message via AIM to marsfrogie
You will be able to get it very close, but if the grains are in any way different, you will be able to tell them apart. (barely) The weld could also look slightly different than the joined parts. If the items are cast, you may be able to manipulate the metal grain and get it completely uniform. Only practice will determine if this is possible.
Type of Aluminium. PeterM Anodizing Questions 2 10-14-2004 04:57 AM
streamlining sanding of cast aluminium parts rotorman Metal Polishing Questions 6 05-22-2004 12:09 AM
Aluminium Motorcycle Forks gjricc2 Metal Polishing Questions 4 12-01-2003 03:56 PM
Engravings ands anodised aluminium - off the beaten track whistule Anodizing Questions 2 11-28-2003 10:45 AM
directions for polishing the aluminium parts on my sportbike mrnasti69 Metal Polishing Questions 1 04-29-2003 08:12 AM
