Go Back   Caswell Inc. Metal Finishing Forums > Metal Polishing Questions
Connect with Facebook
Closed Thread
Old 07-09-2003, 03:28 AM
jm jm is offline
jm
Default Aluminum prep for chrome plate
I have machined aluminum plates, 1/4" thick (approx 5" x 8") and
the machined surface seems to be equivalent to using 400 grit sandpaper,
a brushed appearance.
What preparation and products do I need to get these plates polished
before sending it out to the platers for chrome plate?
Is the brushed finished ok now or do I need to use higher grit sandpaper
or can I now use a buffing wheel ? which color of polish do I need to start
considering the grain and which buffing wheels are recommended.
I need to order some stuff. How long does it take to ship to california?
jm
Old 02-02-2004, 01:24 AM
skiddz's Avatar
skiddz
All the platers I've ever used have included the polishing as part of their fee. I have alos gone the other route and done all the polishing prior to taking the parts in for plating. In my experience, the cost for the latter version isn't a whole lot less, but the turnaround is much quicker.
When I do choose to polish myself, I usually just hit the parts with a sisal wheel and black compound until I can't see any more blemishes. I then clean thoroughly and head to the platers.
Shipping to CA usually takes about a week via UPS ground. I have had orders show up in as little as 4 days, but that would be the exception.
Closed Thread
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 10 03-31-2009 06:02 AM
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 01:16 PM
plug n plate chrome on aluminum national84 Electroplating Questions 2 07-02-2005 06:47 AM
Need help with Polishing Aluminum Diamond Plate, real bad. fireman Metal Polishing Questions 2 06-08-2004 09:25 PM
"Brushed" aluminum look on regular alu. plate?? rabiddog22 Electroplating Questions 7 03-21-2003 07:58 PM
