Results 1 to 10 of 10
Thread: Sanding the Welds on Frame to get it ready for Polishing
  1. #1
    Badboy23 is offline Newbie
    Join Date
    Apr 2009
    Posts
    17
    Default Sanding the Welds on Frame to get it ready for Polishing
    I have not found anyone in here with this question.This is probably the most important thing in Prepping a motorcycle frame for Polishing.When U folks sand down the frame how do you take out the Black looking this from the crevices of the welds.I know you Polishers know what I'm talking about.When you sand the frame it's not that bad,then you get to the welds and there deep crevices in the welds,there's still paint or brush aluminum finish in those crevices and believe me you will not knock it out with a Da sander.I can knock it out but it will make the welds flat,and the welds will get weaker. I s there anyway I can take out the paint or brush aluminum finish in the crevices of the welds. Whats a better way in sand the welds to make it real clean!!
  2. #2
    baz
    baz is offline Metal Finishing Guru
    Join Date
    Feb 2006
    Posts
    822
    Default Re: Sanding the Welds on Frame to get it ready for Polishing
    media blasting with a fine glassbead will clean inside the recess areas of the welds prior to polishing .
  3. #3
    Join Date
    Apr 2009
    Posts
    17
    come on folks is this a forum or what. You guys got answers in here? Just one answer thats it. We are here to help each other right? Give me answers boys.
  4. #4
    Tng21 is offline Amateur Metal Finisher
    Join Date
    Dec 2006
    Location
    Dereham, norfolk, UK
    Posts
    106
    you got an answer off baz. He's very exprienced in all aspets of polishing so would just listen to wat he said to be honest lol
    check out baz's website.
  5. #5
    mpierich is offline Metal Finishing Guru
    Join Date
    Aug 2004
    Posts
    957
    Quote Originally Posted by Badboy23 View Post
    What do you want? How many ways do you think there are to do that?
    If you have "deep crevices" in the welds, they aren't real good welds. And even if you get the paint out of the crevices, they'll still look like crappy welds, just polished.
    You could try some good liquid paint stripper.
    Or else grind the welds smooth or pick the paint out with a needle, lol...
  6. #6
    baz
    Join Date
    Feb 2006
    Posts
    822
    like mpierich says , there is not many ways to do that , you blast , you use paint stripper (if it is paint but if it is anodised paint stripper won t work) or you could always grind that weld until it is all flat but i would nt want to ride that bike after that
  7. #7
    Crimepays is offline Newbie Caswell Platinum Member
    Join Date
    Feb 2009
    Posts
    27
    you should just sand the weld marks completely smooth. It'll look alot better and you won't have crevices left to worry about getting any residue out of.
  8. #8
    woodjames's Avatar
    woodjames is offline Metal Finishing Guru
    Join Date
    Nov 2007
    Location
    Rochester NY
    Posts
    629
    That's what I was thinking, it's all about how well the weld has penetrated, not what's on the surface. I've seen plenty of extended swingarms that were smooth, not much that takes more abuse than that.
    Quote Originally Posted by Crimepays View Post
    James Bateman
  9. #9
    baz
    Join Date
    Feb 2006
    Posts
    822
    how do you guys know how well the welds have penetrated ?
    once you have sanded or grinded the weld flat how do you know if you have 1/4 inch thick of material left or if you have 1/32 ?
    do you have a way of checking this or is it guesswork?
  10. #10
    Join Date
    Aug 2004
    Posts
    957
    Quote Originally Posted by baz View Post
    LOL...hey baz, maybe one of the fellas will volunteer to test out the welds on the street...
    Anyhow...polishing frames? Please. In the day, if you were that picky you frenched 'em with Bondo and painted. Then if you didn't know what you were doing the Bondo fell out later, LOL...
Thread Information
Users Browsing this Thread
  1. Sanding/Polishing Die Cast Aluminum HELP
    By stephenr in forum Metal Polishing Questions
    Last Post: 10-08-2008, 06:47 AM
  2. Sanding & Polishing PC ??
    By donafams in forum Powder Coating Questions
    Last Post: 09-06-2007, 10:21 AM
  3. sanding and then polishing tight spots....
    By tweak in forum Metal Polishing Questions
    Last Post: 01-26-2007, 11:19 AM
  4. Getting ready for atv frame
    By clperformance in forum Powder Coating Questions
    Last Post: 10-14-2005, 06:50 AM
  5. After 1500g sanding, and black emery, frame has black streak
    By fizlfry in forum Metal Polishing Questions
    Last Post: 04-26-2005, 10:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
