Results 1 to 3 of 3
Thread: Newbie - advice please - when changing mops do i?
  1. #1
    steptoe is offline Platinum Member
    Join Date
    Apr 2009
    Posts
    1
    Default Newbie - advice please - when changing mops do i?
    Hi all,
    newbie just starting out on the long road of polishing, i have some wheels i wish to mirror finish, i did a set about a year ago but i never quite got them mirror finished!!
    My technique is to sand 240 and then wet and dry up too 1200 then start polishing with a electric wheel mounted on a tyre changer, sounds a bit crazy but i think it will work, took some video on my phone but it would only record for 15sec at a time
    My question is what mop and compound should i start with and when changing mops/compound should i degrease the wheel or just carry straight on with the next stage of cut?
    Thanks in advance
  2. #2
    mpierich is offline Metal Finishing Guru
    Join Date
    Aug 2004
    Posts
    957
    Default Re: Newbie - advice please - when changing mops do i?
    No pictures.
    If your sanding to 1200 is good try brown compound then white.
    Yes, you need to clean one compound off the workpiece before going on with the next.
  3. #3
    smooth72's Avatar
    smooth72 is offline Newbie
    Join Date
    Apr 2006
    Posts
    31
    It is best to change wheels, Especially for white it a loose wheel. Your cutting wheels are much tighter.
Thread Information
Users Browsing this Thread
  1. Newbie here, need advice on powder types
    By DanMan2k06 in forum Powder Coating Questions
    Last Post: 03-06-2009, 05:57 PM
  2. Hi All Newbie in UK looking for advice
    By dave1977 in forum Oven Building Forum
    Last Post: 10-29-2008, 05:57 PM
  3. Newbie in need of advice
    By afterglow in forum Plating Pot Metal
    Last Post: 03-11-2008, 03:38 AM
  4. general newbie advice
    By smokeyone in forum Electroplating Questions
    Last Post: 12-20-2006, 01:27 PM
  5. newbie looking for advice
    By badboy71499 in forum Metal Polishing Questions
    Last Post: 03-03-2004, 01:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
