Okay can someone help clarify the process. i read the Motorcycle Polishing 101...but here is my dilemma. i am polishing my frame with an angle grinder (makita- pretty powerful) and 4 inch pads. I have a few questions
1. how long should i polish each compound onto frame? 10, 15, 20-30 minutes, or an hour each? The frame is pretty smooth..went up to 1000 grit wet with dawn, metal polish, and water.
2. should i use acetone to remove the compounds or should i use a micofiber cloth only OR should i use both acetone and microfiber cloth? Whats the best way to remove the compound from the frame before i move to the next compound which would yeild the best results.
Thanks any help would be appreciated.![]()
LinkBack URL
About LinkBacks
